Totiano* Inviato 29 Dicembre, 2012 Segnala Share Inviato 29 Dicembre, 2012 è un articolo di qualche giorno fa su defencetalk al link http://www.defenceta...ith-ease-45958/, in effetti, ma merita di essere posto in prima pagina su betasom! in sostanza attraverso delle onde di pressione riesce a ricavare un amappa dell'ambiente circostante invece di impiegare sonar ad alta frequenza, AUV eccetera. ecco l'articolo: NTUs sense-ational invention helps underwater vessels navigate with ease NTU scientists have invented a sense-ational device, similar to a string of feelers found on the bodies of the Blind Cave Fish, which enables the fish to sense their surrounding and so navigate easily. Using a combination of water pressure and computer vision technology, the sensory device is able to give users a 3-D image of nearby objects and map its surroundings. The possible applications of this fish-inspired sensor are enormous. The sensor can potentially replace the expensive eyes and ears on Autonomous Underwater Vehicles (AUVs), submarines and boats that currently rely on cameras and sonars to gather information about the environment around them. The revolutionary, low-powered sensor is unlike cameras which cannot see in dark or murky waters; or sonars whose sound waves pose harm to some marine animals. These extremely small sensors (each sensor is 1.8mm x 1.8mm) are now being used in AUVs developed by researchers from Singapore-MIT Alliance for Research and Technology (SMART), a research centre funded by the National Research Foundation. The centre is developing a new generation of underwater stingray-like robots and autonomous surface vessels. The new sensors, made using Microelectromechanical Systems (MEMS) technology, will make such robots smarter and prolong their operational time as battery power is conserved. Associate Professor Miao Jianmin from the School of Mechanical and Aerospace Engineering, and his team of four have spent the last five years in collaboration with SMART to develop micro-sensors that mimic the row of feelers on both sides of the Blind cave fishs body. Associate Prof Miao said the line of sensors present on the fishs body is the reason why it can sense objects around it and still travel at high speeds without colliding with any underwater obstacles. To mimic nature, our team created microscopic sensory pillars wrapped in hydrogel a material which is similar to the natural neuromasts of the blind cave fish into an array of two rows of five sensors, Prof Miao said. This array of micro-sensors will then allow AUVs to locate, identify, and classify obstacles and objects in water through water pressure and also to optimise its movement in water by sensing the water flow. The new sensor array which costs below S$100 to make, is also more affordable than sonars, which can detect faraway objects but not nearby objects and cost thousands of dollars. Partnering Prof Miao to develop the sensors and to adopt it for use on AUVs is Professor Michael Triantafyllou from SMART. Prof Triantafyllou, from SMARTs Centre for Environmental Sensing and Modeling (CENSAM), is one of the worlds foremost experts on creating underwater robots modelled after aquatic animals like fish. Current problems with AUVs include poor navigation in murky or cloudy waters such as those off the coast of Singapore, as underwater cameras can only see a short distance, Prof Triantafyllou said. Other methods like underwater lights and cameras, acoustic navigation, and sonars also work, but they are very expensive and require very high levels of power that drain the batteries. The new sensors are much cheaper and only require small amounts of power. Also, sensors like sonar are loud and invasive and they may harm aquatic animals that also use sound waves to navigate, the Massachusetts Institute of Technology professor added. The aim of the AUVs is for environmental sensing, to detect environmental pollution, contaminants and to monitor the overall water quality in Singapores waters. The AUVs will have chemical sensors installed to detect the chemical condition of water (dissolved oxygen, nutrients, metals, oils, and pesticides), and biological sensors to monitor water conditions such as harmful bacteria and pathogens. Other potential application of these MEMS sensors, which specialises in near-field detection include defence applications. These can detect nearby submarines without the use of sonar thatgives away ones location. This collaborative research resulted in two breakthrough papers being accepted for presentation at a prestigious MEMS conference next January in Taiwan, organised by the Institute of Electrical and Electronics Engineers (IEEE). One paper is for the development of the piezoelectric sensor which does not require any energy as it generates an electric voltage when water flows past the feelers. The second paper focuses on a low-powered biomimetic sensor which can detect underwater objects even when there is little water flowing past it. To further improve the sensor, Prof Miaos team is now looking to develop a hybrid sensor which will combine both the zero-energy piezoelectric sensors high accuracy with the low-powered static sensors ability to detect objects in still water. Source: Nanyang Technological University Citare Link al commento Condividi su altri siti More sharing options...
Lefa Inviato 29 Dicembre, 2012 Segnala Share Inviato 29 Dicembre, 2012 ..One paper is for the development of the piezoelectric sensor which does not require any energy as it generates an electric voltage when water flows past the ‘feelers’. The second paper focuses on a low-powered biomimetic sensor which can detect underwater objects even when there is little water flowing past it.. Molto interessante! Quindi per la navigazione un po' più sostenuta utilizza la linea di elementi pizoelettrici, mentre per quelle più lente uno scanner biometrico! I trasduttori con materiali pizoelettrici (di solito ceramici) trasformano una vibrazione in una tensione elettronica proporzionale all'intensità della vibrazione, al contrario se energizzati producono una vibrazione (sonar passivo/attivo); come riescono a sfruttare questa tecnologia per la navigazione? parlano di pressione dell'acqua (quindi lavorerebbe in 'passivo') immagino relazionata alla propria andatura e al cambiamento dei flussi in ragione di eventuali elementi circostanti, ma come può vedere distante? Citare Link al commento Condividi su altri siti More sharing options...
Totiano* Inviato 30 Dicembre, 2012 Autore Segnala Share Inviato 30 Dicembre, 2012 non ho trovto nent'altro in rete, Matteo. A naso direi che, piu delle onde di pressione prodotte dallo spostamento dello scafo, potrebbe essere qualcosa generato dalla corrente. Citare Link al commento Condividi su altri siti More sharing options...
lazer_one* Inviato 30 Dicembre, 2012 Segnala Share Inviato 30 Dicembre, 2012 i sensori piezoelettrici si basano sull'effetto omonimo: se il materiale viene sollecitato meccanicamente esso genera una tensione proporzionale alla forza (pressione) oppure se gli viene applicata una tensione si dilata/comprime di conseguenza. Questo tipo di sensori sono molto sensibili alla pressione e possono, soprattutto, fornire informazioni sulla dinamica della pressione applicata in tempo reale ovvero senza inerzia data dagli strumenti.... ma questo è roba vecchia! la novità sta nell'aver realizzato dei dispositivi MEM ovvero dei dispositivi che integrano componenti meccaniche (il trasduttore) con componenti elettroniche che penso siano di prima elaborazione del segnale: giusto per capirci realizzare un circuito integrato con una buona intelligenza a bordo dotato di sensore/sensori piezo... mi metto a cercare maggiori info Citare Link al commento Condividi su altri siti More sharing options...
dott.Piergiorgio Inviato 31 Dicembre, 2012 Segnala Share Inviato 31 Dicembre, 2012 (modificato) non so... di sicuro il nome del prof. puzza di pesce, in senso ittiologico.... Saluti, dott. Piergiorgio Modificato 31 Dicembre, 2012 da dott.Piergiorgio Citare Link al commento Condividi su altri siti More sharing options...
mdm1977 Inviato 2 Gennaio, 2013 Segnala Share Inviato 2 Gennaio, 2013 sembrerebbe un device biomimetico che si basa sullo stesso principio della linea laterale dei pesci (http://www.lescienze.it/news/2009/08/31/news/svelato_il_segreto_del_sesto_senso_dei_pesci-573759/) . In questo sistema periferico sono presenti dei array di trasduttori sensoriali (neuromasti), che integrando le diverse informazioni assolvono a diverse funzioni. Oltre alla percezione delle onde sonore traducono informazioni riguardo temperatura, salinita' e velocita' dei flussi del fluido circostante. Credo che l'aspetto su cui si basa il sistema sens-Ational sia fondamentalmente quest'ultimo della dinamica dei fluidi, ovvero dalla mappa dei flussi attorno al pesce potrebbe essere possibile ricostruire l'ambiente circostante. Citare Link al commento Condividi su altri siti More sharing options...
