raalst Inviato 8 Dicembre, 2007 Segnala Share Inviato 8 Dicembre, 2007 Ciao tutti ! il mio modello di CB-20 sta progredendo. Si transformerà in nella a radiocontrolled il sommergibile di modello (dopo un certo tempo.) my model of CB-20 is progressing. It will become a radiocontrolled model submarine (after some time..) sorry the italian text is translated by babelfish :s68: I bought the plans from ANB Citare Link al commento Condividi su altri siti More sharing options...
andreavcc Inviato 9 Dicembre, 2007 Segnala Share Inviato 9 Dicembre, 2007 :s20: really a good work!!! what diving system you mean use? Citare Link al commento Condividi su altri siti More sharing options...
raalst Inviato 9 Dicembre, 2007 Autore Segnala Share Inviato 9 Dicembre, 2007 (modificato) Andrea, I will make a watertight compartment from a drainage pipe. I plan to use the space between the pipe and the sides of the hull als ballast tanks. this will get the sub from surface to almost submerged. the last bit of the dive I plan to do with a small trimtank. I want the periscope to be above the water all the time, because I want to use it as a video/wifi antenna. so dive control must be good. One of the problems I think about now is where to have the openings in the completed hull to reach the electronics and mechanics. The photo is the original model, I will make a rubber cast from it, and with the cast I will create the polyester hull. I have a building log at another forum : you can see it here but my speed of building is low.. Modificato 9 Dicembre, 2007 da raalst Citare Link al commento Condividi su altri siti More sharing options...
andreavcc Inviato 9 Dicembre, 2007 Segnala Share Inviato 9 Dicembre, 2007 it does not import the speed, important is the result :s02: :s20: you have intention to use it in salt water or fresh water? Citare Link al commento Condividi su altri siti More sharing options...
raalst Inviato 9 Dicembre, 2007 Autore Segnala Share Inviato 9 Dicembre, 2007 R/C does not work if antenna is in salt water, It must be fresh water only. as the periscope is out of the water it could be possible to use it at sea, but the lake is big enough to loose the sub! I don't need the sea for that :s03: Citare Link al commento Condividi su altri siti More sharing options...
Charlie Bravo Inviato 9 Dicembre, 2007 Segnala Share Inviato 9 Dicembre, 2007 Hi Raalst. Thanks for your pic, the details of the hull look to be very accurate. Have you seen this with some CB photos in Trieste ? http://www.betasom.it/forum/index.php?showtopic=21997 ... and let us see your model pictures when it's completed of course ! Bye :s55: Citare Link al commento Condividi su altri siti More sharing options...
raalst Inviato 9 Dicembre, 2007 Autore Segnala Share Inviato 9 Dicembre, 2007 Yes, the photo's of the trieste sub were a great help. These photo's were posted because I asked for information on this forum. I am very grateful for that help ! I also have the book (caproni e il mare). I visisted also the CB-20 in Zagreb technical museum. Citare Link al commento Condividi su altri siti More sharing options...
Sag75 Inviato 14 Dicembre, 2007 Segnala Share Inviato 14 Dicembre, 2007 Hi, great job! did you buy plans from ANB? that's good choice, me too. I bought a plan from there to building my r/c Minerva corvette.. have a nice working.. S.75 Citare Link al commento Condividi su altri siti More sharing options...
raalst Inviato 15 Dicembre, 2007 Autore Segnala Share Inviato 15 Dicembre, 2007 yes, I got the plans of ANB. A very friendly italian gentleman bought them for me. He had not seen me before ! The on-line show did not work, and he had to contact the secretary of the ANB to get the plans. That is another man I am very grateful to. later on, it appears that the general shape is OK on the plans, but the details look very different on the Zagreb Submarine. for example : the floodholes on the deck, the way the hatches open, and the form of the tail. From the book it ia also very clear there were a lot of variations in how these boats were built. Citare Link al commento Condividi su altri siti More sharing options...
