prima_legio
TWoS nuovi interessanti aggiornamenti
Prima di tutto vi ringrazio tanto per il sostegno:smile:
Domani esattamente dopo 2 mesi, 25/6-25/8 si torna finalmente a casa :thumbsup:
Nel frattempo girando qua e là ho trovato questa discussione:
" @TREVALLY
In the GroupEditor there are choices for taskforces/escorts tactics:-
Early
Mid
Late
@ZEDI
In the GroupTypeDefs.cfg, here is an example:
ExternalCargo=-1
InternalCargo=-1
CrewRating=2
Weapons=0
Sensors=0
Tactics=0
Camouflage=0
0 can be changed up to 2 and 3 which is Medium and Late. In stock campaign most of the units were set as Poor or Competent and tactics on 0 or 1, just to make thing easy. Now after 43 the escort will use 3, everything set at maximum.
We asked you if is possible to control the AI tactics in certain timeframes.. like having the AI noobish in 39-42 but extremely aggressive in 45-45? If they use in 39 the same tactics um
sed in 45.. is no fun and realism"
@TDW
A, ok. Yes I plan on (trying to) cloning the AI sensors files and adjusting them to 'dumb down' the AI in early part of war and 'harden' them in late part of war. What I was planning on doing was making 3 steps of difficulty in the AI sensors:
- years '38-middle '42 AI will be dumb down
- years middle '42-middle '44 will be like they are now
- years '44 on will be made very difficult"
Alla fine TDW ci rinunciò da quel che ho capito....Abbiamo mai guardato in quel file.."GroupTypeDefs.cfg"?
Si può far nulla ? L'idea di suddividere le tattiche come diceva TDW mi intriga parecchio, da lunedi riaccendo I motori dell'uboat (ci vuole!!!!! ) e poi darò un occhiata li.
A proposito avete  caricato l'ultimo aggiornamento,rilascio il 28 luglio?:
TWoS v2.2.14 changelog:
- Added tooltips description how to use built in Navmarks/Supermars functions.
- Updated events.ini file by Tonci87. Corrected Grossdeutscher Rundfunk radio station news broadcast dates trough out the entire war.
- Improved XO TDC dialogs - Auto TDC active/inactive.
- Added missing star shell guns and ship whistles for several merchant types and auxiliary cruisers.
- Added missing search lights for several merchant types and auxiliary cruisers.
- Nation's roster historical fixes as suggested by kapuhy.
- Various "under the hull" campaign file fixes and improvements."
Luca
Se mi avessi detto che usciva Silent Hunter 6 ero meno felice 😀
E' la più bella notizia che ci potevi dare !!!!
Dopo una lunga missione oceanica rientra alla base e goditela !!!
Spalletti a fiumi !!!!!!
Grazie Fausto :biggrin:
Spalletti per tuttii!!
E domani si risale sull' U-27, il mio equipaggio scalpita
:submarine:
8 hours ago, fanghino said:
Un grosso in bocca al lupo!
Grazieeee fanghino :biggrin:
Ho installato aggiornamento messo a puntino il tutto, e domani si salpa,è ora di una nuova carriera, il baltico mi aspetta.
Ciao Luca! Sono felicissimo per il tuo ritorno, ci sei proprio mancato! Forse ci incontreremo sulle stesse rotte, perché anche io sono ripartito da Memel con l'ultimo update 2.2.14, anzi sono già sulla rotta per Scapa Flow con il mio U-28 e con il mio capitano di fiducia "Richin da Sturla" promosso da bagnino a capitano e  noto personaggio insieme al cognato Sarvatu (Salvatore) entrambi di Sturla  (ridente sobborgo di Genova) che animavano negll anni cinquanta i Bagni Ninin.
Ad maiora!
:submarine:
Maurizio
Edited by GatoClass
Ad maiora!
:submarine:
Maurizio
Grazie mille Maurizio
Sono partito, intendo fare un video sull'uso di Enigma,appena ricevo il primo messaggio faccio partire il video, unico problema non ho microfono,quindi devo editare video (non l'ho mai fatto prima, quindi ci vorrà tempo) a meno che mi capiti l'occasione di un microfono...ma dubito.
Spero che questa guida su Enigma possa essere utile 😀
Luca
Grazie Luca! Stai facendo un lavoro veramente interessante!
Da parte mia nessuna novità, sono ripartito con l'update 2.2.14 di nuovo da Memel (eletto cittadino onorario ormai!) quando scopro il nuovo update 2.2.15. Chissà quali novità ci saranno! Vado per scaricarlo e vedo nelle note scritte da vdr1981:
v2.2.15
- Fixed typos in Events.ini file which could cause CTD on certain dates.
Ma come? Un update da 23.57 MB solo per modificare il file events.ini di soli 22.001 Byte? Almeno risulta essere l'unica modifica dichiarata.
Sarò all'antica ma invece di chiamarlo update non bastava creare un piccolo MOD da attivare con JSGME e che si può scaricare in 1 secondo?
Il file events.ini è veramente importante se si utilizza la stazione radio Grossdeutscher Rundfunk , perché contiene 4 errori introdotti solamente nell'update 2.2.14 che fanno colassare SH5 al desktop quando si è alle date 24.05.1941 02.06.1941 e 03.10.1941, quindi la strade sono due: o eliminare la stazione radio e il riferimento in radio.ini o scaricare il "piccolo" update 2.2.15 di soli 23MB.
Mi permetto allora di mettere a disposizione, invece di scaricare l'elefantiaco update 2.2.15, questo piccolo mod virusfree "Grossdeutscher Rundfunk Fix" che in un attimo sistema un errore fondamentale. Il MOD è da scompattare nella cartella MODS o nella cartella TWoS_Parts se si utilizzano gli exe autoestraenti di vdr1981 per essere attivato quindi con JSGME.
Il link:
http://www.mediafire.com/file/abxnko2wd16fozp/Grossdeutscher_Rundfunk_Fix.zip/file
GatoClass
P.S. Nei prossimi update di TWoS che dovrebbero contenere modifiche sostanziali, il file events.ini corretto sarà già compreso, quindi il mio piccolo mod potrà essere eliminato
Edited by GatoClass
v2.2.15
Il link:
GatoClass
Ciao Maurizio, non me ne ero accorto dell'aggiornamento!
in effetti se il cambiamento è solo quello,non capisco il motivo di aver rilasciato addirittura un update...misteri di Vecko😎
Grazie infinite per il Link mediafire, provvedo ad installarlo subito.a
Intanto tra oggi e domani  conto di terminare spiegazione Enigma.
Ciao Luca
Edited by prima_legio
Ciao Luca! Credo che tu abbia scaricato il piccolo mod per il fix dell'events.ini. Sono risalito al post in cui si metteva a disposizione il nuovo events.ini in quanto l'originale conteneva grossi errori storici che sono stati corretti. Purtroppo nel compilare il nuovo events.ini sono stati aggiunti degli spazi dopo l'estensione ".ogg" ma i file ogg ai quali faceva riferimento non avevano questo spazio aggiunto all'estensione e di conseguenza quando venivano richiamati dall'events.ini modificato ovviamente non venivano caricati e non trovandoli l'eseguibile mandava in crash SH5. Lo dico perché Vecko ha perfettamente ragione nel consigliare generalmente di non aggiungere o modificare elementi. Basta uno spazio aggiunto che, avendo comunque un proprio valore esadecimale, può mandare in crash SH5 perché non previsto e non trovato.
A me era successo molti anni fa con SH4 un fatto analogo: ad una certa data andava in crash sistematicamente. Dopo ricerche estenuanti ho trovato che nell'events.ini di una stazione radio c'era un maledetto spazio: eliminato lo spazio tutto era di nuovo ok!
Luca mi hai veramente incuriosito con l'Enigma. Si può attivare in ogni momento TWoS  Encrypted BdU Orders, anche se sono in vista di Scapa Flow?
Grazie!
Maurizio
On ‎04‎/‎09‎/‎2019 at 18:25, prima_legio said:
Aperta nuova discussione con video e spiegazioni su Enigma
Wow (non la MOD 😉 ), vado a cercarla subito !!!
 La guida è terminata
dimmi se così può andare o in cosa potrei migliorarla, grazie
Ringrazio pubblicamente GatoClass per avermi dato le dritte ed i mezzi per risolvere il problema con l'eseguibile di sh5, finalmente posso tornare in mare.
Sono in debito Maurizio, apriremo una bottiglia di Spalletti :smiley28:
Ciao Luca!
quindi hai scaricato l'upgrade di SH5 alla versione 1.2 e l'hai lanciato e ha aggiornato SH5 risultando compatibile con TWoS? Se è così e come speravo io sono veramente proprio contento! In Subsim ho visto che in Download SH5 Game patches c'è l'upgrade 1.2 messo in share da BL!TZKR!EG che è uguale a quello che ti ho passato. Bene vuol dire che quello che tu mi hai scaricato era il file giusto!
Adesso mi sto dedicando a SH4 specialmente del punto di vista grafico: cielo, nuvole, mare. Il più lo sta facendo mikehcl che è iscritto in Betasom, vecchia mia conoscenza di quando era uscito SH4, e sto facendo da tester. Io ho invece modificato un po' di file per personalizzare un po' SH4, pescando da altri mod e facendo magari alcune cambiamenti.
Sai che ti dico? Che forse per me SH4 è più coinvolgente di SH5 e se non sbaglio sei proprio stato tu a raccomandarmi LAA assolutamente indispensabile con il mio nuovo computer con 32 Gb.
Grazie a te!
Quindi siamo in pareggio Luca e non in debito. Vedi è quello che ho sempre pensato che debba funzionare in una comunità in share, le mie piccole scoperte più quelle fatte da altri e rese pubbliche posso essere di grande aiuto per tutti, anche per chi sta solo a guardare, non avendo nè tempo nè voglia nè capacità per mettere mano a un programma.
Ciao Luca! e sperem sempre per l'Italia e noi del Veneto!
Maurizio
Edited by GatoClass
19 hours ago, GatoClass said:
Ciao Luca!
Grazie a te!
Maurizio
Ciao Maurizio
io ho fatto così installato sh5 sostituito .exe
Poi ho aperto Uplay messo spunta su "no update"
Lanciato gioco, uscito subito.
Riaperto Uplay e messo "sempre offline".
ora TWoS posso installarlo.
Ehi felice di SH4 a proposito si riesce a giocare con Puntamento Manuale o è ancora tutto come prima? ( Recon manuale incompleto e stadimetro non affidabile)
Ciao e Sperem!
PS io intanto reinstallo con l'ultima versione di Fotrsu se vi serve una mano felice di far parte della squadra :Italy:
