Steffsap Inviato 30 Giugno, 2004 Segnala Share Inviato 30 Giugno, 2004 Tra poco disponibili dalla White Ensign Models (hanno prezzi assurdi, sono inglesi, ma sono bravi!) PE 7211, 1/72 U-boat Torpedo Loading Set, including 2 resin G7 Torpedoes with PE for G7a or G7e variants; PE 7212, Resin G7 Torpedoes (x2), including PE for G7a or G7e variants, suitable for use with the Revell 1/72 U-boat, Revell 1/72 S-100, or Airfix E-boat. Citare Link al commento Condividi su altri siti More sharing options...
Steffsap Inviato 2 Luglio, 2004 Autore Segnala Share Inviato 2 Luglio, 2004 Da Steelnavy: MGM white metal castings MG100/12 Resting 20mm Flak crew with lifejackets MG100/13 20mm Flak crew with lifejackets in action MG100/14 20mm Flak crew at rest (may need to mod uniform) MG80/41 37MM Flak M42 on C36 mount (mount needs to changed to that from the S-100 kit.) Correct gun is : MG80/42 37mm SKC730U in U-boat mount (Not in production at this time - but hopefully soon. I will need to call Mike and ask him when he will start production again) Micro Realistixx from Germany XX72028 German boat crew Bad weather dress Mars M7237 Different German weapons. Exquisitely detailed MG34's. Schatton Flak barrels: 7202 3.7 CM Flak 36/37 barrels ( you gotta see these to believe the detail in 1/72 ) 7201 20 mm Flak barrels 2cm Flak 38 (KwK 38) Vierling Barrels Possible other crew sets. I haven't seen pics yet, so I think with a little modifications you can get more Flak crews for naval subjects Milicast: MILFIG3 German 20mm Flak crew 5 figs: 39-45 MILFIG11 German 37mm Flak crew 5 figs:41-45 The MGM figure sets are comparable to the H&G U-boat crew sets. Citare Link al commento Condividi su altri siti More sharing options...
Steffsap Inviato 2 Luglio, 2004 Autore Segnala Share Inviato 2 Luglio, 2004 Contains: 20mm Fittings, Aft Torpedo Loading Hatch, Amidships Deck Hatches, Attack Periscope Mount Footbars, Ballast Tank Vents, Biscay Cross, Bollard Tops, Bow Lower Cable Cutter, Bow Torpedo Tube Doors, Bow Upper Cable Cutter, Cable Tensioners, Compass & Engine Telegraph Dial, Con Tower Top Side Vent Grills, Conning Tower Hatch Mechanism, Conning Tower Markings, Conning Tower Side Vent Grills, Deck Hatch Hinges, Diesel Exhaust, Diving Tank Valve Outlets, Fore Deck Hatches, Forward Torpedo Loading Hatch, FuMo 61 Antenna, FuMo29 Antennas, FuMo30 Radar Antenna, Gun Deck Hatch, Gun Handwheels, Hatch Handles, Large Casing Access Hatch, Naxos Antenna, Periscope Compass Repeater, Periscope Stiffeners, Replacement Rail, Retractable Bollard Plates, Small Stern Access Hatch, Snorkel Housing Crosses, Torpedo Aimer Sight Bezel, Torpedo Aimer Sight Footbars. Citare Link al commento Condividi su altri siti More sharing options...
Steffsap Inviato 5 Luglio, 2004 Autore Segnala Share Inviato 5 Luglio, 2004 Citare Link al commento Condividi su altri siti More sharing options...
Steffsap Inviato 16 Luglio, 2004 Autore Segnala Share Inviato 16 Luglio, 2004 http://www.modelbrass.com/revell_viic-installed.htm' target='_blank'> Citare Link al commento Condividi su altri siti More sharing options...
Steffsap Inviato 30 Luglio, 2004 Autore Segnala Share Inviato 30 Luglio, 2004 Link con le istruzioni Citare Link al commento Condividi su altri siti More sharing options...
LUCA Inviato 4 Agosto, 2004 Segnala Share Inviato 4 Agosto, 2004 SEI UNA MINIERA !!!!!!! :s02: Citare Link al commento Condividi su altri siti More sharing options...
Steffsap Inviato 29 Agosto, 2004 Autore Segnala Share Inviato 29 Agosto, 2004 Tra poco disponibili dalla White Ensign Models (hanno prezzi assurdi, sono inglesi, ma sono bravi!) PE 7211, 1/72 U-boat Torpedo Loading Set, including 2 resin G7 Torpedoes with PE for G7a or G7e variants; PE 7212, Resin G7 Torpedoes (x2), including PE for G7a or G7e variants, suitable for use with the Revell 1/72 U-boat, Revell 1/72 S-100, or Airfix E-boat. i prezzi: Well, having finally gotten casting cost quotes on our 1/72 torpedoes, we have set prices on: PE 7211, Torpedo Loading Set, including all handling/loading equipment, hatch cover & dogging latch, and two resin G7 torpedoes with PE fins and propellors, priced at £13.58 (£15.95 for UK/EU customers); and, PE 7212, two G7 torpedoes with PE fins and propellors, priced at £3.36 (£3.95 for UK/EU customers). Pre-order now, and we'll be shipping the sets as soon as the torpedoes arrive. You can take a look at the PE portions of both sets on our website. Citare Link al commento Condividi su altri siti More sharing options...
