LINK
per sole....US $510,000.00
Vehicle Description
The 48-passenger VOYAGER submarine was designed in Finland and built in 1994 in the US; it made 11,000 dives in Honolulu, Hawaii during commercial operation from 1995 to 2001. Currently, the submarine is fully operational; ABS and USCG certified. It has new batteries and new acrylic passenger and pilot viewports. Included are all the support equipment: Air and oxygen compressors, battery charges, all suited in marine containers; also set of spare parts included.
VOYAGER Submarines are great for conventional tourist submarine operation, V.I.P underwater excursions or for conversion into a luxury underwater yacht for personal use.
Main Technical Characteristics:
Passenger Capacity - 48
Crew - 2-3
Design Depth - 328 feet
Max. Speed submerged - 5 knots
Max. Speed Surface - 7 knots
Gross Tons - 98
Length Overall - 73 feet
Width Overall - 9.9 feet
Height Overall 22.5 feet
Draft - 10,4 feet
Freeboard (waterline to top of the hatch) - 2.8 feet
Battery Power:
High Voltage Battery Capacity - 248 Volts/1080 AH
Low Voltage Battery Capacity - 24 Volts/880 AH
Emergency Battery Capacity - 24 Volts/640 AH
Converters: 110 v and 12 V
Hydraulic Propulsion:
One Main Thruster 105 HP
2 Verticals and 2 Lateral Thrusters 13 HP each
One Pilot's Viewport diameter - 3.6 feet
Passengers' Viewports - 24, diameter 29 inch
Navigation:
Electronic and Magnetic compass
Depth Monitoring
Echo Sounder, Speed log, Water Temperature
Underwater Camera and Video Monitors for Pilot and passengers
Emergency Life Support:
Minimum 72 hours for a full load of passengers and crew
Vehicle Condition
The submarine has steel hulls in sound structural condition and meet USCG and NFPA 302 requirements per its last inspection. The vessel has 24 view ports of 30" in diameter and two watertight deck hatches for entry and exit.
Terms of Sale
Payment: 10% deposit of the purchase price by way of certified check/wire transfer within 24 hours of auction completion. Balance within 14 days. Buyer is responsible for the shipment of 99+ ton vessel however, seller recently sold the sister submarine and shipping experience and will assist the buyer in shipping the vessel.
:s03: :s03: :s03: :s03: :s03: :s03: :s03: :s03:
dai.. mi accontento anche di un cannone da 105"  con MG coassiale
Guarda che non e' un carroarmato :s03: :s03:
Uomo di poca fede.... Non Guardavi Mai l'A-Team ? :s11: , poi qui a Betasom abbiamo i migliori ingegneri della flotta :s02:
Guest Scorpio
Avrei un baril.... una cosa ingombrante da portarmi appresso...
Una sola??????
Non ci credo :s04: :s04: :s04: :s04: :s04: :s04: :s04: :s04:
RAGAZZI ora dirò una "bestemmia" : SONO ASTEMIO  :s11: :s11:
Marescià ma accettiamo ancora ufficiali che sono stati in convento? Mi passi subito un fiasco che debbo riparare a questa bestemmia.
:s11:
Bene, comandante
Finalmente l'uomo giusto per risollevare le sorti di Betasom 2003.
Perche? Ma per le ormai troppo frequenti perdite di battelli ed equipaggi nel corso delle missioni!
Vi sono almeno due ordini di motivi, sui quali si è soliti stendere il pietoso velo delle solite giustificazioni.
1°) Le incoercibili gare di rutti, fra l'equipaggio (comandante in primis) del battello in missione e fra battelli del branco. Questo ha portato come conseguenza alla facile individuazione degli stessi da parte dei DD alleati (altro che sonar attivo e radar!) ed alla strenua caccia, il cui epilogo è sintetizzato dalla frase: "Soccombette dopo ore di insistenti attacchi dei destroier con cariche di profondità..."
2°) Le atmosfere interne dei battelli, sature di vapori etilici (è nota la destinazione reale delle riservette proiettili) che durante la navigazione in immersione, innescate da qualsiasi scintilla o fiamma libera, (leggi onnipresenti toscani) provocano disastrose esplosioni, concluse dalla frase: "Un' altro battello è andato perduto per cause imprecisate. Le unità amiche in zona hanno percepito una unica potente esplosione..."
Alla salute, comandante!
Pugno di ferro, bocche cucite, minerale e gazzosa!
:s03: :s03: :s03: :s03: :s03: :s03: :s03: :s03: :s03: :s03: :s03: :s03: :s03: :s03:
      527.2k
