TWoS nuovi interessanti aggiornamenti
prima_legio
Dopo molto tempo ho dato uno sguardo a SH5 TWoS, ci sono novità, 2 nuovi aggiornamenti,da sottolineare (finalmente) l'attenuazione dell'AI e della precisione dei Merchant, infatti sembrava che l'equipaggio fosse composto da tiratori scelti.
La novità mi ha decisamente stuzzicato,e così eccomi a scaricare di nuovo SH5.
Vi farò sapere le prime impressioni. Ecco comunque il Changelog degli ultimi 2 aggiornamenti,interessante soprattutto il 2.2.11
v2.2.10
- New loading screen. Special thanks to gap and Edward Tambunan who has actually repainted the photo (U-96).
- Watch crew will now report bearing as well when group of units/convoy is in sight.
- Enhanced tooltip instructions for external torpedo reserves transfer in order to avoid confusion how to utilize this ability.
- Player's submarine in Monsun Gruppe campaign chapter ("silentotto" start) is changed to type VIIC since it is still too early for VIIC/41.
- Player's submarine in Turning Point campaign chapter ("silentotto" start) is changed to type VIIC instead of U-Flak. To start this campaign chapter using U-Flak, enable "Campaign Start_VIIB_UFlaK" addon prior your campaign start. In normal gameplay and without this add on enabled, U-Flak will be offered to player from mid 1943 to the end of the year, depending of current player'a rating.
- Edited starting bases of several campaigns in order to avoid unnecessary instant jumps between bases at the end of campaign chapter. Almost all base/flotilla transfers will be followed by the appropriate encrypted and unencrypted radio messages...
- Few more minor tweaks and fixes.
v2.2.11
- Added Gutted's solution for annoying repetitive crew voices when using certain in-game functions: torpedo settings (salvo, depth, speed, pistol settings), map course plotting ect...
- The visual sensor affected by available light for all AI units modifier has been changed from 0.0 to 0.5. This should effectively reduce overall spotting distance of all in game AI units. (Disable all patches in your Generic Patcher and restore the snapshot again to activate the changes*)
- External torpedoes reserves transfer cool-down time has been reduced from seven to two days.(this tweak requires new campaign start*)
- Reduced accuracy of 3-inch and 4.7-inch guns used on some allied merchant ships.
Modificato da prima_legio
  • Risposte 169
  • Ultima Risposta
Ciao prima_legio,
da un po' di tempo mi sono staccato da SH5 per vari motivi. Uno di questi motivi è l'AI che per come è impostata in TWoS la trovo totalmente assurda e irreale. Non è possibile che  l'AI avversaria fosse così precisa, quasi a mira laser da Guglielmo Tell. Avevo sempre sperato che Vecko avesse preso atto che la realtà non sempre è sinonimo di difficoltà ma a quanto pare solo adesso con la versione 2.2.11 ha ridotto la precisione e solo per i Merchants.
Io ho provato a diminuire la frequenza degli attacchi aerei e ci sono riuscito ma non sulla precisione, ho cambiato alcuni valori in main.cfg perché con la Time Compression raccomandata, uno si trovava già colato a picco senza sapere chi ringraziare. Non sono riuscito a diminuire la precisione della mira sia navale che aerea. Bisognerebbe sapere quali file toccare. Tu ne hai un'idea?
Ciao!
GatoClass
Modificato da GatoClass
11 hours ago, GatoClass said:
Ciao prima_legio,
Ciao!
GatoClass
In effetti hai ragione al 200% anch'io avevo mollato proprio per questo.
Allora per me il responsabile numero 1 è TDW IRAI 0_0_41
hai provato a dare un occhio a questo file per esempio?(riguarda Visuale, Radar e Idrofoni AI devo però trovare Gun....
###################### Difficulty parameters ####################
# Note: difficulty is in range 0.0 - 1.0 with 0.0 being no difficulty (sensor doesn't exist)
    # for non-merchants
    VISUAL_DIFFICULTY_MIN        = 0.90;
    VISUAL_DIFFICULTY_MAX        = 1.0;
    HYDROPHONE_DIFFICULTY_MIN    = 0.80;
    HYDROPHONE_DIFFICULTY_MAX    = 1.0;
    RADAR_DIFFICULTY_MIN        = 0.80;
    RADAR_DIFFICULTY_MAX        = 1.0;
    SONAR_DIFFICULTY_MIN        = 0.80;
    SONAR_DIFFICULTY_MAX        = 1.0;
    # for merchants
    VISUAL_DIFFICULTY_MERCHANT_MIN    = 0.85;
    VISUAL_DIFFICULTY_MERCHANT_MAX    = 1.0;
    HYDROPHONE_DIFFICULTY_MERCHANT_MIN = 0.80;
    HYDROPHONE_DIFFICULTY_MERCHANT_MAX = 1.0;
    RADAR_DIFFICULTY_MERCHANT_MIN    = 0.80;
    RADAR_DIFFICULTY_MERCHANT_MAX    = 1.0;
    SONAR_DIFFICULTY_MERCHANT_MIN    = 0.80;
    SONAR_DIFFICULTY_MERCHANT_MAX    = 1.0;
###################### Submarine consts #########################
la ricerca continua
la ricerca continua
Ho aperto l'update,le modifiche che cerchiamo  credo siano fatte nella cartella Library,credo che sia qua che dobbiamo cercare...
Questo è il "Gun 3inch"
8 hours ago, Von Faust said:
Ottimo, appena ho un po' di tempo (è un periodo veramente caldo per i simulatori sottomarini) lo scarico. Che voi sappiate sarà necessario far ripartire la Campagna ?
Credo di no,Vecko scrive solo che la versione 2.2.9 e successive non sono compatibili con le precedenti ,da 2.2.8 in giù,io almeno lo interpreto così...spero di non sbagliare 😊
 E questo è il 4.7inch..(sempre preso dall'update, di Vecko ).ora però come si associa alle navi?nel file "sea" ci sono delle navi,.all 'interno c'è solo il file .Sim.ma non credo siano proprio tutte quelle interessate (c'è anche una nave ospedale tra queste***) bisognerebbe studiare meglio quei file.. senz'altro qua ci hanno messo le mani..
Ho un idea..da testare sul minelayer gryff che col witcher ( mi sembra di ricordare) sono le prime 2 navi che incontriamo ad inizio campaigna...apro il file Gryff GR2 faccio merge con file Gun (oppure il .sim e modifico alterando i valori in "turret"?..boh).ad esempio azzero le munizioni,modifico l'elevazione,salvo e faccio test se il Gryff non mi spara ..qualcosa ho capito... Se non cambia nulla oppure Anche il witcher non mi spara...significa che Nulla ho capito...comunque credo che il Santo graal si nasconda li tra i file in library e la cartella .sim
Che ne pensate?
***A guardar meglio invece la nave ospedale, e quache altra NON ha il file .Sim ma solo un file di informazioni, credo per il rec.man...la cosa inizia ad avere senso...mi manca tutto il resto della ricetta però
Ottimo lavoro prima_legio!
Hai ragione a provare con il minelayer Griff che è la prima nave con il Wicher che è un DD.
Ok a: "azzero le munizioni,modifico l'elevazione ecc." e se mai ridurrei anche il range o lo azzererei.
Ho passato un sacco di ore stanotte a cercare di capire dove sono i parametri delle varie armi navali.
Un primo file è
guns.sim
che è il file che ha modificato Vecko e a me sembra che non contenga tutte le armi navali e se mai solo per i mercantili.
Il file che contiene i cannoni che dovrebbe avere il Griff e anche il Wicher è
guns_TCM.sim
che è inserito da Vecko nell'ultimo upgrade ma non modificato rispetto alle versioni degli upgrade precedenti e quindi in questo file avrei trovato i due cannoni in dotazione al Griff, come ho visto nel file "NML_Gryf.eqp" (dentro la cartella "NML_Gryf" a sua volta contenuta nella cartella "Sea").
In guns_TCM.sim ci sarebbero i due tipi di cannoni in dotazione al Griff
4.7In_Ansaldo_turret_IT
5in_SK_C34_turret_GER
che per un motivo che non conosco si trovano nel file guns_TCM.sim con il nome leggermente cambiato in
4_7InchDouble_Ansaldo_IT_barrel
5Inch_Single_C34_barrel
Quindi per esempio proverei a cambiare i parametri in questo file.
Io per semplicità uso Silent 3ditor v0.9.9 senza passare da Goblin editor e dal file GR2 dato che tutti i parametri del file sono numerici e non stringhe che ti obbligano ad usare il GR2 con il merge. Ma vedi tu come ti trovi meglio.
Il Wicher sembra dal suo file ".eqp" che abbia 5
quindi i valori cambiati in guns_TCM.sim dovrebbero essere validi sia per il Griff che per il Wicher.
Altri cannoni e AA avversari quindi della GB credo che siano contenuti nel file
guns_radars_01.sim
in Library\ShipParts
Ad esempio il DD Tribal ha 4 "4In_double_MkXVI_turret_GB" che ho trovato come cannone nel file "guns_radars_01.sim".
Quindi, passo successivo, si potrebbero cambiare i valori dei singoli cannoni che sono previsti nei rispettivi file .upc delle navi nemiche nella cartella Sea. Ma sarebbe un lavoraccio!
Comunque a rendere innoqui sia il Gryf che il Wicher sarebbe un enorme passo avanti, poi si tratterebbe di modificare la precisione in qualche modo.
Forse nella variabile Fire in trav_tolerance e in elev_tolerance ma questo è ancora un mistero!
Ciao! Appena ho qualche risultato ti faccio sapere.
GatoClass
Un primo file è
guns.sim
guns_TCM.sim
guns_radars_01.sim
GatoClass
Complimenti GatoClass ottimo lavoro per davvero!! Ora son di colloqui insegnanti per mia figlia domani a casa Dal lavoro...credo farò notte bianca su PC oggi!
Ho visto che ne gryf ne witcher hanno file gr2..controllerò meglio comunque... Immagino dovrò andare di S3d..ho un pò perso la mano,intanto ho provato a contattare Vecko, ma come dici tu è  restio a condividere idee,credo che col fatto che accetta donazioni trova conveniente tenere tutto per sè,comunque se ho novità le pubblico subito.
Luca
Ciao Luca!
direi ottime notizie. Ho provato con Silent 3ditor a modificare i valori nei due file che ti ho scritto prima.
Ho provato per ora in una missione prima senza il mod di modifica e dopo con il mod che ho creato. Prima in emersione ero cannoneggiato alla disperata, dopo con il mod non sparavano più ed ero io a farli fuori con il cannone di bordo. Devo però trovare ancora un cannone che mi è sfuggito. Ho modificato guns_radars_01.sim per rendere innocua la classe DD Tribal ma devo trovare ancora un altra classe di DD inglesi di cui per ora mi scappa il nome per verificare se hanno un cannone diverso. Ho anche reso innocua la classe Battleship QueenElizabeth che era presente nella missione.
Ho modificato anche il file guns_TCM.sim per il Griff e il Wicher ma devo ancora provare il tutto con una nuova carriera. Solo che così i nemici sono azzerati...dobbiamo trovare il modo per renderli solamente meno precisi. Speriamo bene!
Ciao!
Maurizio
P,S, Credo che i cannoni e gli AA siano collegati alle rispettive navi nel file .upc
2 hours ago, GatoClass said:
Ciao Luca!
Ciao!
Maurizio
It's a long way to Tipperary,
It's a long way to go.
To the sweetest girl I know!
Goodbye Piccadilly,
Farewell Leicester Square!
It's a long long way to Tipperary,
But my heart's right there.😀😀
Credo sia svelato uno dei segreti dell'universo,L'accuratezza!!
Dipende SOLO ed esclusivamente dalla "Velocità di elevazione" valori :  0.0-10 (Ma devo controllare il valore Max )gradi al secondo...più si avvicina allo 0 minore è l'accuratezza,il Max è la perfezione.Piu di così difficile simularla
Ora nascono i problemi però..solo con le navi che hanno la cartella ".sim" riesco a far modifiche, col Gryf ed il Witcher mi è impossibile (cioè io non ne sono capace) inoltre bisogna capire come applicarle
solo a determinate nav...determinati Gun e non indiscriminatamente....insomma è solo l'inizio.
comunque si parte da sh5/data/library/shipPart/GunRadars.sim... Proprio quelli che aveva indicato prima GatoClass.
PS ora detto tra  noi vado a rilassarmi e torno tra un paio d'ore...lunga notte mi sa...
Luca
Non sono ancora a conoscenza del valore Max
Ciao Luca!
Dipende SOLO ed esclusivamente dalla "Velocità di elevazione" valori :  0.0-1 gradi al secondo...più si avvicina allo 0 minore è l'accuratezza,1 è la perfezione.
Comandanti !!! Vi sto seguendo, siete incredibili !!!!
Spero di allinearmi con le vostre conoscenze per darvi una mano.
Avanti tutta !!!!
Avanti tutta !!!!
Grazie Fausto, il merito è di GatoClass in primis per aver indicato su quale file intervenire.
Poi comunque c'è una cosa da dire, l"accuratezza come vera e propria opzione non esiste, quindi si deve trovare la soluzione migliore, questo è stato il punto di partenza e rallentare la velocita di alzo è la soluzione che credo più simula questo.
Intervenire drasticamente su altri fattori,come ha giustamente detto e notato dopo i test da GatoClass snatura troppo la simulazione,aspetto comunque anche l'opinione di GatoClass può essere  che si possa fare ancora meglio,( per esempio io sarei d'accordo anche sulla diminuzione del difficult visual max range merchant )oppure che questa strada non è conveniente.
A onore del vero è stato Luca ad indicare la cartella Library come quella contenente i file che regolano i parametri fondamentali. Con un motore di ricerca che è contenuto in Total Commander (ottimo e per me indispensabile gestore dei file ma esiste anche Free Commander che è free ed è analogo), bene con questo motore di ricerca ho cercato di individuare i file della cartella Library che contenevano in tutto o in una parte la parola della quale Vecko aveva lasciato traccia, cioè in particolare 4.7-inch guns e la ricerca mi ha portato al file "guns_TCM.sim" confermato anche dalla sua data di creazione e da lì sono riuscito a trovare anche il riferimento al 3-inch. Fatto questo con Silent 3ditor ho scansionato le 18 chiavi presenti e aprendo di ognuna di queste la sottochiave relativa sono riuscito ad individuare le due chiavi che riguardavano il 4.7-inch e il 3-inch. Ognuna di queste chiavi contiene molti parametri modificabili riguardanti il cannone o la AA.
Penso che Luca dica bene sulla velocità di alzo in gradi, se la si diminuisce la mira dovrebbe impiegare di più ad allinearsi alla curva parabolica di impatto teorica e nel frattempo l'obbiettivo si è di nuovo spostato e probabilmente anche la velocità di spostamento in gradi dovrebbe contribuire a diminuire l'accuratezza.
Domani provo solo questi due parametri tralasciando le modifiche precedenti e creando un nuovo mod.
Sperem!
Ciao a tutti!
P.S. Luca, confermo i tuoi dubbi sul max range nella realtà di un cannone. Per esempio per un cannone da 4.7 inches è previsto un range di 15.500 mt, ora fra ora di avvistamento, condizioni metereologiche ed altro mi sembra eccessivo. Se ricordo bene ho letto che di notte con navigazione in affioramento la torretta poteva essere vista dai 3-3.5 km di distanza trascurando le fasi lunari, quindi anche il max range potrebbe essere diminuito.
C'è da considerare quello che hai fatto notare su VISUAL_DIFFICULTY_MIN e MAX.
Maurizio
Ciao a tutti!
Ho provato a diminuire la velocità in alzo e in spostamento laterale in gradi del cannone in dotazione alla classe  DD Tribal ma non ho visto risultati apprezzabili.
Ho provato un'altra opzione, quella del Fire dove ci sono 2 parametri: trav_tolerance e elev_tolerance entrambi a 1,0 come valore in gradi e ho cambiato il valore per entrambi i parametri da 1,0 gradi a 50 gradi, giusto per vedere cosa potesse succedere e ho diminuito il range del cannone a 3.000 mt per avere dei risultati molto evidenti.
Caricando la solita missione ho visto che i cannoni dei DD classe Tribal sparavano con un alzo esagerato, cioè più o meno con quei 50 gradi che avevo impostato e che con il sommergibile in emersione riuscivo sui 4.000 mt di distanza a cannoneggiare senza che i DD rispondessere al fuoco (avevo impostato il cannone GB a 3.000 mt sempre per la classe Tribal) e sono riuscito a colare a picco 3 DD, poi la corazzata Queen Elizabeth ha pensato bene di farmi fuori, ma per questa nave non avevo fatto nessuna modifica ai suoi cannoni, quindi il tutto era logico.
Ecco qualche risultato l'ho ottenuto ma non è quello che voglio. Vorrei che i DD avversari sparassero al mio sommergibile con la stessa precisione che è concessa al cannone del sommergibile, con dei tiri anche  random e non sempre letali.
Non credo che sia una cosa impossibile, ma al momento il tutto è al di sopra delle mie già scarse conoscenze.
Comunque non mollo, perché ci sono sicuramente altri parametri da trovare e da cambiare.
Ciao!
GatoClass
Sperem!
Ciao a tutti!
Maurizio
Ciao Maurizio
Accidenti ero convinto che l'alzo avrrebbe avuto maggior effetto..
Capisco che intendi e son convinto anch'io che ci deve essere il modo!!
Ascolta voglio provare con s3d..però mi serve il tuo aiuto.. Son impedito con S3ditor,spiegami passo passo come entrare nella modifica gun elevation del Gryf per esempio( Mi son fissato con questo)
Cioè entro in sea/ gryf/apro il file. sim Con s3d e poi?  Mi son perso in un bicchier d'acqua..lo so ma l'ho sempre usato per sciocchezze
Luca
P.S. che missione fai di test, cosi la provo uguale stasera
Per Caso hai installato S3D configurator su S3D 099?.Ho visto ora questo strumento,manco sapevo esistesse ma sono con smartphone e non su PC... Prima di stasera non posso fare nulla
Aggiunto P.S.
Ciao Luca!
Sinceramente non so cosa sia S3D configurator, il programma che uso è Silent 3ditor v0.9.9 che lo puoi trovare con google oppure da "http://s3d.skwas.com/".
Non utilizzo Silent 3ditor (che adesso chiamo S3d per brevità) per aprire i file .sim delle navi nella cartella Sea per modificare cannoni, AA e altre parti oltre al fatto che il Gryf non sembra che abbia un file .sim se mai lo si può utilizzare per modificare la stazza, lunghezza, pescaggio ecc. ma non l'armamento.
Prima cosa in Sea cerco la cartella riferita alla nave che mi interessa, quindi per il Gryf la cartella da aprire è NML_Gryf quindi vado ad aprire con un notepad il file NML_Gryf.eqp che contiene tutto l'equipaggiamento:
[Equipment 1]
NodeName=M01
LinkName=4.7In_Ansaldo_turret_IT
StartDate=19380101
EndDate=19451231
[Equipment 2]
NodeName=M02
LinkName=5in_SK_C34_turret_GER
StartDate=19380101
EndDate=19451231
[Equipment 3]
NodeName=M03
StartDate=19380101
EndDate=19451231
[Equipment 4]
NodeName=M04
StartDate=19380101
EndDate=19451231
[Equipment 5]
NodeName=A01
LinkName=20mm_single_Oerlikon
StartDate=19380101
EndDate=19451231
[Equipment 6]
NodeName=A02
StartDate=19380101
EndDate=19451231
[Equipment 7]
NodeName=A03
LinkName=NULL
StartDate=19380101
EndDate=19451231
[Equipment 8]
NodeName=A04
LinkName=40mm_Double_Bofors
StartDate=19380101
EndDate=19451231
[Equipment 9]
NodeName=A05
StartDate=19380101
EndDate=19451231
[Equipment 10]
NodeName=T01
LinkName=NULL
StartDate=19380101
EndDate=19451231
[Equipment 11]
NodeName=T02
LinkName=NULL
StartDate=19380101
EndDate=19451231
[Equipment 12]
NodeName=W01
LinkName=NULL
StartDate=19380101
EndDate=19451231
[Equipment 13]
NodeName=W02
LinkName=NULL
StartDate=19380101
EndDate=19451231
[Equipment 14]
NodeName=L01
LinkName=reflector_base
StartDate=19380101
EndDate=19451231
[Equipment 15]
NodeName=L02
StartDate=19380101
EndDate=19451231
; ++++++ The End +++++
Se noti il Gryf usa le seguenti armi:
40mm_Double_Bofors che è un cannone antIaereo
20mm_single_Oerlikon che è un AA e non dovrebbe essere usato contro una nave nemica, ma non si sai mai
Questo è il primo passo che faccio per avere la lista dell'armamento dal file .eqp per le navi che mi interessano.
Da quello che ho capito gli armamenti sono contenuti in due file che si trovano in Library:
guns_TCM.sim
e nella sottocartella ShipParts
guns_radars_01.sim
Questi due file .sim contengono i cannoni, AA e altro per tutte le navi. Quindi se si modifica per esempio 4.7In_Ansaldo_turret_IT, allora verrà modificato per tutte le navi che lo prevedono nei rispettivi file .eqp. Non so se si possa personalizzare il singolo cannone per la singola nave.
PRIMA PARTE
SECONDA PARTE
Adesso sono in difficoltà perché io cercavo l'armamento per il DD Tribal per la missione che uso per testare le modifiche. Ho la versione originale in italiano di SH5 quindi molte missioni le ho in italiano. Quella che uso è "Contro ogni previsione" del 13/4/1940 con lo scopo di affondare la corazzata Warspite vicino a Narvik in Norvegia che nella cartella SingleMissions ha il nome SM02, spero che  lo sia anche nella versione in inglese.
La mia difficoltà è che per il Gryf ho trovato due cannnoni e non le due AA nel file guns_tcm.sim ma ci sono tutti i cannoni e le AA nel file guns_radars-01.sim.
Non vorrei farti perdere del tempo con il Gryf ma forse è da utilizzare solo il secondo file cioè
guns_radars_01.sim
Speriamo che ci sia tutto in questo file!!!
Allora con S3d apri guns_radars_01.sim (copia di sicurezza) e ti appare sulla sinistra una colonna con i numeri solo pari e crescenti dal 2 al 136.
Ti faccio un esempio: se clicchi sul numero 14 si apre il 15, clicca su questo numero dispari e sulla destra appare in una finestra più grande una descrizione.
Clicca ora su obj_Turret (la prima voce in alto) e appare in Barrel il nome dell'arma. In questo caso al numero 15 corrisponde "20mm_vierling_barells_GER" che a noi non interessa perché è un'arma GER ma è per capirci.
Sotto vedrai Traverse poi Elevation e se ci clicchi avrai in sequenza min max speed.
Continuando hai shell_speed recol_time ecc. Arriva a Range che in questa arma è 7235,0 mt adesso per variare clicchi su range=7235,0 e in basso si apre la finestrella Value. Qui FINALMENTE puoi cambiare il valore del Range.
Dopo Range c'è ammo_storage e Fire. Clicca su Fire e avrai due valori tutti 1,0 in gradi, bene se ci clicchi li puoi cambiare in Value e mettere il valore che vuoi. Io avevo messo il valore 50 gradi tanto per avere ben chiaro l'effetto.
Ricordati di fare il save se vuoi mantenere le modifiche.
CONTINUA
Grazie per la spiegazione GatoClass, davvero esauriente,credo purtroppo che ho io qualche problema con S3D... magari domani ti sèpiego meglio,comunque ho modificato anch'io l'elevazione delle armi del Gryf con Goblin( il 4.7 ed il 5inch ,e di conseguenza di tutte le altre navi che hanno sti cannoni,come hai detto anche tu,chissà se si potrà selezionare una specifica nave(forse con Goblin,ma dovrò provare) a dirti la verità una lieve differenza mi sembra di averla notata ripeto Lieve(,e forse dovuta al caso,ho potuto provare 2 volte non di più,quindi prendila con le pinze),ho fatto la missione "Test Gryf" ma per sicurezza dovrei modificare anche l'AA infatti mi hanno sparato anche con quelle.
Una domanda volevo farti,perchè aprendo in ShipParts il file "GR2" poi merged con "Gun.sim" ho trovato 2 valori di "speed elevation" sia con 4.7In_Ansaldo_turret_IT che col 5in_SK_C34_turret_GER  allora volevo chiederti,quando hai modificato la velocità di alzo il valore di partenza che c'era era speed10 oppure speed 0.7 ? fammi sapere quando puoi, e grazie ancora per la guida.
Luca
Il valore di alzo era 0,7 ma sicuramente l'ho ridotto a 0,1
TERZA PARTE
Purtroppo non ci sono scorciatoie o elenchi per trovare subito l'arma che ti interessa cambiare. Devi cliccare su un numero pari per fare apparire il numero successivo, quindi cliccare su questo numero dispari e nella finestra a destra cliccare su "obj_turret" si vedranno il nome dell'arma in Barrel. Se è l'arma che ti interessa, continuando a cliccare puoi attivare il parametro che ti interessa, quindi cliccando su un singolo parametro da variare, potrai variarne il valore nella finestrella più bassa cioè Value e appare anche una breve descrizione sul valore che stai cambiando o anche solo per avere un'informazione un po' più chiara del numero che appare.
Se è tutto Ok, alla fine dei cambiamenti devi dare un Save per memorizzare il tutto.
Quindi è un lavoretto un po' lungo trovare la posizione col numero dispari di quello che ti interessa e ti consiglio di scriverti questo numero e la descrizione che hai cliccando su obj_Turret che leggi in Barrel. Ti potrebbe essere utile in un futuro.
Ciao Luca!
Maurizio
Prima di tutto ancora grazie Maurizio per l'aiuto,seguito la tua guida,e devo dire che pensavo S3D più macchinoso con SH5,invece è stata una piacevole sorpresa,anche se credo che alcuni file hanno per forza bisogno di Goblin, tutto sta nel farci la mano Ucon uno o l'altro.Torniamo alla nostra ricerca, ho ripetuto ancora Test, ed i dubbi mi son rimasti,con value 0.1 forse in effetti ho notato qualche errore di troppo da parte del nemico,i miei dubbi però rimangono.
1-Sarà stato solo un Caso?
2-stiamo parlando di un valore prossimo allo 0.0 non dovremo quindi vedere maggior numero di missed hit?
Nella missione Gryf test ci sono anche 2 aerei Tedeschi che attaccano il Gryf, può essere che la mia impressione di minore accuratezza,sia dovuta ad una questione "priorità" del Gryf,(ha badato un pò meno a me)dovrei eliminare I 2 aerei per avere un test più attendibile.
Intanto ho RI-chiesto una dritta a Vecko, il primo tentativo è andato a vuoto,mandato sms e nessuna risposta, provo un ultima volta specificando il punto a cui siamo arrivati,magari sarò più fortunato.
Ma credo ci dovremo arrangiare.
Certo mi rode essere passato dall'entusiasmo di qualche post fae poi constatare che il comportamento dell'AI non è cambiato come pensavo,ma non mollo l'osso! 😎 😀
Continua sotto...
Collego 2 post
(prosegue dal post precedente)
Ad esempio abbiamo mai provato ad aggirare il problema? Cosa influenza la precisione? Provo a fare un elenco(se avete qualche altra idea aggiungete)
-le caratteristiche dell'arma(alzo inclinazione ecc)
-le condizioni del mare e del meteo/ stabiltà della nave (non modificabili per ovvie ragioni)
-l'esperienza dell'equipaggio( questo è un punto interessante)
Questa sera proverò ad approfondire le csratteristiche dell'equipaggio, magari non approdo a nulla,ma chissà
Per esempio Impostare l'equipaggio merchant come poor o novice potrebbe cambiare qualcosa? Magari abbinandolo con la velocità di alzo?
Son solo esempi di cose che possiamo provare, che altro fattore può influenzare un tiro?
Luca
Ciao Luca!
ti devo ringraziare perché mi hai incuriosito con Goblin e stanotte ho provato a riutilizzarlo, era da molto tempo che non lo usavo. Con Goblin nel nostro caso si individuano molto più velocemente le armi, anche perché si riconoscono con il nome esatto usato nel file .eqp. Ho provato con il Gryf ad azzerare i colpi dei cannoni e a parte i due aerei tedeschi, sono riuscito a cannoneggiarlo in emersione senza che rispondesse ai colpi. Non cambia niente rispetto a prima che già si sapeva ma almeno si sa che anche Goblin fa ottimamente il suo lavoro.
Oggi vorrei ancora capire dove Vecko ha messo le mani per ottenere: "Reduced accuracy of 3-inch and 4.7-inch guns used on some allied merchant ships".
In più Vecko ha modificato "units avail.light visual sensor    stock (0.5/1.0)  / (0.5/0.5)  TDW_SHSim_Patch.s5p/ better for dusk /on in snapshot" e devo vedere se c'è qualcosa da verificare nel file TDW_SHSim_Patch.s5p, non si sa mai!
Ciao!
Maurizio
Ho l'impressione che Vecko si tenga per se le scoperte che fino l'altro ieri non sapeva come trovare e che ora dica: "Beh io mi sono fatto il c*** così per trovare certe cosette, adesso siiete voi adessos a scoprirle da soli. Niente pappa pronta ma gustatevi un bel exe intanto". Solo che sui suoi file exe hanno trovato pane per i suoi denti. Che mica lancio un exe che mi modifica le mie impostazioni e i miei mod!
Sai cosa faccio?
Mi creo una cartella di comodo e dico all'exe di TWoS di installare le sue cosine in questa cartella. Poi con TotalCommander (gestore di file e strumento molto potente per file e cartelle e ricerche inter ai file) vado a controllare i reali cambiamenti rispetto alla versione precedente. Di quello che mi sembra utile ne faccio un bel mod che installo con JSGME nella cartella MODS e non in TWoS_Parts come si vorrebbe, quindi aggiungo i miei mod che non hanno mai creato problemi si instabilità e sono ben 48 mod fra i miei e quelli resi pubblici che metto dopo i primi 8 di TWoS.
Te ne dico una. Tempo fa in subsim un tizio dice che per lui il manuale di riconoscimento è troppo chiaro se visto di notte. Allora mi sono messo e ho rettificato prima la luminosità e il contrasto di tutte le bandiere poi le immagini delle silouette di tutte le navi previste nel manuale: 63 bandiere da uniformare in contrasto e luminosità e altrettante immagini dei profili delle navi. Ne faccio un mod e ne pubblico il link e Vecko mi scrive in un post: "Beh ok ma a me non interessa" e che credeva che volessi la sua benedizione per aggiungerlo in TWoS? A me piace mettere a disposizione tutto quello che faccio se lo ritengo valido e non per gloria. Sai quanti utilizzano il mio pulsante di sparo dei siluri con la lucina rossa? E il filmato Das Boote departure e la lampada che oscilla sopra il tavolo degli ufficiali. Mai fatto il conto ma anche se è piaciuto ad uno solo sono contento.
Riconoscendo a Vecko un lavoro incredibile, ma se accettasse di più i pareri degli altri non sarebbe umano ma divino!
Maurizio
Sai cosa faccio?
Maurizio
Complimenti GatoClass!!
Non sapevo dei tuoi lavori per SH5.
Le mie conoscenze si fermano molto molto prima,comunque son daccordo al 100% su quello che hai scritto,trovo giusto condividere Ed accettare consigli, in questo effettivamente Vecko non ci sente,l'ho notato anch'io da certe risposte stizzite che dà sul forum magari anche a chi semplicemente non capisce un semplice passaggio nell'installazione.
Quello che mi lascia perplesso è che lui solo rimanga/voglia rimanere il custode dei segreti, fornendo anche in PM risposte sempre incomplete o non rispondendo affatto,è suo diritto ci mancherebbe!! Però..peccato.
L'esatto contrario di quel che accade con FOTRSU dove tutti possono partecipare con prove e consigli, ed I modder principali sono una vera squadra che ascolta ed aiuta per quello che può ( qui però il fatto è che SH4 ha difetti credo insuperabili di fondo..ahimè).
Detto questo son STRA-daccordo con te che è giusto sottolineare che Vecko ha fatto un lavoro incredibile e molti utenti si sono avvicinati o sono ritornati a SH5 proprio grazie alla sua MOD. Ma se fosse più aperto alle critiche ed ai consigli son sicuro che SH5 migliorerebbe ancora di più.
PS domanda fuori tema
Maurizio hai ancora SH3?
Che MOD di base Usi ( GWX, nygm...eccetera)
Luca
Ciao Luca!
ti ringrazio innanzitutto per i tuoi apprezzamenti.
Sì ho ancora e perfettamente installato SH3 con GWX come MOD di base. Mi sono divertito con SH3 fino a quando anni fa ho cambiato il monitor che da 4:3 di proporzione era diventato 5:4 con il nuovo ma in questo modo l'immagine si allungava e avevo tutti gli scope, quadranti ecc. ovalizzati e non c'era nessun modo per rettificare le proporzioni. Poi fortunatamente ho trovato in rete il modo per risolvere e così l'ho sistemato. Per me la grafica conta moltissimo, non so se te ne sei accorto!
Ma presto sono passato a SH4 che mi affascinava di più per motivi diversi e in questo ho imparato a crearmi i miei piccoli mod personalizzati, grazie anche a JSGME che è una manna dal cielo per chi vuole provare dei mod. Il MOD di base è RSRDC_SH15_V550. Mi sono divertito moltissimo come fosse un film hollywoodiano, è che con tutte le emittenti radio e con in tramonti incredibili che vedevo dalla torretta mi sembrava veramente di essere in mezzo al Pacifico. Da bambino avevo visto troppi film con sommergibili americani contro i giapponesi!!!
Ritornando a Sh5 per adesso ma solo per adesso mi fermo. Lascio decantare un attimo le idee perché non so dove andare a sbattere.
La storia di SH5 è stata travagliata fin dall'inizio. Nel bel mezzo della progettazione alcuni programmatori più importanti se ne sono andati per altre strade. I rimasti con l'arrivo di alcuni nuovi hanno cercato di finire il progetto per metterlo sul mercato, ma con un'enormità di aspetti non terminati o se mai solo abbozzati. Ma era sempre affascinante per il nuovo teatro di guerra e per l'idea di ricreare l'atmosfera del film Das boot (per me non perfettamente riuscita).
Comunque fortunatamente c'è stata una marea di appassionati che si sono buttati su SH5 per migliorarne gli aspetti in termini di realtà e di grafica. Fra questi TheDarkWraith, bravissimo come programmatore (chiuso nei suoi segreti come Vecko) ma non eccelso nella grafica e Reaper7 che era un mago della grafica. Reaper7 aveva proposto a TheDarkWraith la sua collaborazione per rendere Sh5 ancora migliore ma il suo aiuto non fu accettato. In seguito ci fu un fiorire di mod di tutti i tipi fatti da persone che purtroppo oggi non si vedono più. Se ricordo bene fu Sober (ma non l'unico) a fare un elenco di vari mod con tanto di link per scaricarli uno a uno e più o meno aveva fatto un bel lavoro. Alla fine è arrivato Vecko che ha riunificato tutti i mod ritenuti validi, cercando di eliminare i crash di SH5. Lavoro veramente encomiabile. Il suo mod TWoS, se ti ricordi, era inizialmente in formato .rar poi decise di tramutarlo in un file exe autoestraente che poteva andare bene per i neofiti, ma non per me. Gli chiesi il motivo di questo cambiamento e mi disse che non ce la faceva più a rispondere a tutti sui vari aspetti dell'installazione e altro, così decise per l'exe autoestraente: "prendere o lasciare"! Sono corso ai ripari usando una cartella di comodo, ci scarico l'exe e poi scelgo quello che mi interessa riunificando in un mod che attivo con JSGME.
Cambiando argomento, avevo letto che avevi scoperto il modo per velocizzare il caricamento di SH5 eliminando il manuale di riconoscimento. Come si fa? Mi sarebbe utile per fare le varie prove che conosciamo!
Maurizio
16 minutes ago, GatoClass said:
Ciao Luca!
Maurizio
Da OFEV ---> SOAN----->metti false salvi ed è fatta.. Scappo che son di pausa lavoro ciao
Luca
Nella mia ricerca sull'AI nemica mi sono imbattuto in questo ( è sempre il famigerato TDW IRAI.
Le navi nemiche hanno un "ciclo" di efficenza creato da Tdw nel mod IRAI, senza dubbio un genio!il ciclo è regolabile dal file silent hunter data \ Scripts \ AI \ init.ai in dettaglio :
############### watch rotation and  fatigue #####################
    SHIPWATCHROTATION = 180;            # in minutes (there are 4 tiers of fatigue) this is a base time
    SHIPFATIGUEMIN = 0.50;                # min time of current tier (ShipWatchRotation / 4) when next tier starts
    SHIPFATIGUEMAX = 1.50;                # max time of current tier (ShipWatchRotation / 4) when next tier starts
    SHIPFATIGUESENSORREDUCTIONCRUISEMIN = 0.015;    # min sensor reduction amount for each tier in cruise
    SHIPFATIGUESENSORREDUCTIONCRUISEMAX = 0.03;    # max sensor reduction amount for each tier in cruise
    SHIPFATIGUESENSORREDUCTIONALERTMIN = 0.025;    # min sensor reduction amount for each tier in alert
    SHIPFATIGUESENSORREDUCTIONALERTMAX = 0.05;    # max sensor reduction amount for each tier in alert
    SHIPFATIGUESENSORREDUCTIONDAMAGEDMIN = 0.035;    # min sensor reduction amount for each tier in damaged
    SHIPFATIGUESENSORREDUCTIONDAMAGEDMAX = 0.07;    # max sensor reduction amount for each tier in damaged
    SHIPFATIGUESENSORREDUCTIONDAMAGEDALERTMIN = 0.045;    # min sensor reduction amount for each tier in damaged
    SHIPFATIGUESENSORREDUCTIONDAMAGEDALERTMAX = 0.09;    # max sensor reduction amount for each tier in damaged
Il valore 180 (rosso,in minuti ) è il ciclo della fatica (chiamiamolo così)in questo caso 3 ore,in queste 3 ore l'equipaggio nemico, secondo una formula matematica e con un moltiplicatore random(numeri viola) attraversa i 4 livelli di fatica,al termine di queste 3 ore il ciclo ricomincia,simulando il "cambio della guardia"nell'equipaggio.
Questo la spiegazione da TDW,
"Now I need to explain some things about the new additions for the ship AI:
there is a base watch crew time (in minutes) for each ship:
ShipWatchRotation = 180;
every ship starts with crew with no fatigue. It then determines the time before the first fatigue level by:
intervalTimeCP = (ShipWatchRotation + Ship:Random( -( ShipWatchRotation * 0.25 ), ShipWatchRotation * 0.25 ) ) / 4.0;
this says take the 180 and add a random value somewhere between -25% and +25% of 180 to it and then divide the result by 4. This gives the time before the 1st fatigue level
every ship then determines it's own fatigue levels (4 of them). Each fatigue level determines it's time by:
this says take the 180 and add a random value somewhere between -25% and +25% of 180 to it and then divide the result by 4. This gives the fatigue level time. This repeats 3 more times
after the 4th fatigue level the watch crew is relieved by a 'fresh' watch crew with no fatigue.
Now as each fatigue level is attained, each sensor of the ship will degrade in performance some random amount (simulating fatigue). Each sensor degrades it's own random amount.
All of this makes for a truly random ship AI. You can be stalking a ship thinking you're at safe distance only to find that it changes watch crew and now you're detected! The vice versa is also true: you might be hunted by an escort and over time as fatigue sets in it may 'lose' contact with you allowing you to escape.
Everytime the ship changes state (cruise, alert, damaged, etc.) the watch crew is relieved by a fresh crew with no fatigue."
Modificando SHIPWATCHROTATION si potrebbe intervenire indirettamente sull'efficenza ma il cambiamento ha effetto su TUTTE le navi nemiche
Questa invece è la sezione  "Difficulty parameters" # Note: difficulty is in range 0.0 - 1.0 with 0.0 being no difficulty (sensor doesn't exist)
    # for non-merchants
    VISUAL_DIFFICULTY_MIN        = 0.85;
    HYDROPHONE_DIFFICULTY_MIN    = 0.85;
    RADAR_DIFFICULTY_MIN        = 0.85;
    SONAR_DIFFICULTY_MIN        = 0.85;
    # for merchants
    HYDROPHONE_DIFFICULTY_MERCHANT_MIN = 0.85;
    RADAR_DIFFICULTY_MERCHANT_MIN    = 0.85;(occhio a modificare il Radar, valori inferiori a 0.60 sono a rischio CTD)
    SONAR_DIFFICULTY_MERCHANT_MIN    = 0.85;
Le navi nemiche useranno i loro sensori in modo casuale all'interno del range tra valore Min e Max anche questi valori possono essere modificati a nostro piacere
Per chi non sa da dove iniziare questo è una piccola guida, veloce veloce
1.0 a 0.95  molto difficile (1.0 è la massima efficenza)
0.95 a 0.9  difficile
0,9 a 0,8   difficoltà medio alta
0,8 a 0,7   difficoltà media
0,7 a 0.6   difficoltà medio bassa
0,5 a 0.4   difficoltà bassa
meno di questo valore non li prenderei in considerazione,ma chi vuole può impostare pure 0.0-0.0 .
Luca
Innazitutto Buona Pasqua Luca! Ottima ricerca!!! Ho visto che qualcuno ha modificato dei valori in init.aix e probabilmente deve essere stato Vecko ma le differenze sono minime probabilmente, valori inseriti in TWoS 2.2.0:
# for non-merchants
    # for merchants
tanto per dire da 0.90 a 0.85 nella prima riga.
Molto interessante la scalettatura delle difficoltà che hai scritto, per esempio:
solo che per l'utilizzo aumenterei l'intervallo fra min e max visto che sono valori presi in modo random all'interno dell'intervallo.
Ciao! Maurizio
Ciao Maurizio e Buona Paquetta
Ottima la tua idea sul giocarsela coi parametri Min - Max
In effetti avendo più range di casualità,dovrebbe essere meglio per noi.
Intanto ecco un nuovo aggiornamento da Vecko,diverse correzioni sulla campagna,inutile negarlo a Vecko dovremmo fare un monumento, peccato che sul punto AI nemica stavolta non ci sian novità..
v2.2.12
- Edited Baltic early war sea traffic lines.
- Fixed problem where Polish merchant ships were occasionally trying to pass trough the Kiel kanal while trying to defect to Great Britain during the invasion of Poland.
- Defecting Polish ships will now be taken from Free Poland roster so they can be attacked without penalties for player even after Poland has been conquered.
- Reworked Operation Weserübung: British and German task forces routs departure dates and group compositions. *Note that near the coast operations can not be simulated due to AI limitations.
- Removed excessive number of both British and German task forces during the invasion of Norway.
- Fixed problem where British task forces will just disappear after their final way point is reached during the Operation Weserübung. Instead, they will patrol the designated area for several days and return to Scapa Flow.
- Edited/added set of radio messages which will instruct the player how to behave during the Operation Weserübung, when to start and stop attacking Norwegian ships...
- *All campaign changes require new campaign start in order to be activated but this is not mandatory if your current playtrough date is well beyond april 1940.
- Polish Grom destroyer 3D model is replaced with more historically accurate British R class, instead of used Tribal.
P. S. Visto che Vecko non risponde in PM,ha pure la casella piena e non non può ricevere messaggio, ho scritto sul forums magari lui o qualche altro ci danno la dritta giusta.
Luca
Ciao Luca, buona Pasquetta anche a te!
Ho appena letto in subsim la domanda che hai fatto a Vecko. Meglio di così non potevi fare, sei stato chiarissimo! Ho visto che il file guns_radars_01.sim era già previsto in IRAI e che Vecko ha a sua volta modificato, fatto analogo per il file init.aix. Suppongo quindi che Vecko sappia dove mettere mano se ha modificato i due file per cambiare la Ai nemica. Credo che Vecko non intenda e non permetta ad altri con dei suoi suggerimenti modificare l'impostazione di base di TWoS e riporto quello che si legge nella pagina iniziale nel presentare il nuovo mod TWoS: "...you'll find your submarine very vulnerable to enemy fire..." Quindi se non cambia la sua filosofia, la vedo ardua in un suo aiuto, ma lo strano è che pochissimi abbiano fatto notare l'eccessiva difficoltà poco realistica e perlomeno avere la possibilità di scegliere al momento dell'installazione il grado di difficoltà.
Penso di fare un piccolo mod lavorando solo su init.aix e sugli intervalli min-max tipo: 0.4 min - 0.7 max con estremi ben differenziati in valore per avere risultati più evidenti e ti farò sapere.
Una curiosità, dove hai trovato questi intervalli min max?
Maurizio
Maurizio
Grazie Maurizio
Si trova tutto in
"  Ubisoft \ Silent Hunter 5 \ data \ Scripts \ AI \ init.aix "
Controlla comunque, perchè ora son di lavoro e non ho con me PC.
Se non lo trovi fammi sapere.
Benvenuto iscandar
Ciao Luca,
ho provato in init.aix con questi valori cioè min=0.4 e max=0.7 cioè
# for non-merchants
    VISUAL_DIFFICULTY_MIN        = 0.40;
    VISUAL_DIFFICULTY_MAX        = 0.70;
    HYDROPHONE_DIFFICULTY_MIN    = 0.40;
    HYDROPHONE_DIFFICULTY_MAX    = 0.70;
    RADAR_DIFFICULTY_MIN        = 0.40;
    RADAR_DIFFICULTY_MAX        = 0.70;
    SONAR_DIFFICULTY_MIN        = 0.40;
    SONAR_DIFFICULTY_MAX        = 0.70;
    # for merchants
    VISUAL_DIFFICULTY_MERCHANT_MIN    = 0.40;
    VISUAL_DIFFICULTY_MERCHANT_MAX    = 0.70;
    HYDROPHONE_DIFFICULTY_MERCHANT_MIN = 0.40;
    HYDROPHONE_DIFFICULTY_MERCHANT_MAX = 0.70;
    RADAR_DIFFICULTY_MERCHANT_MIN    = 0.40;
    RADAR_DIFFICULTY_MERCHANT_MAX    = 0.70;
    SONAR_DIFFICULTY_MERCHANT_MIN    = 0.40;
    SONAR_DIFFICULTY_MERCHANT_MAX    = 0.70;
e nella missione che io uso cioè la SM2 nella cartella SingleMissions; la missione presenta la corazzata Queen Elizabeth scortata da 8 DD Tribal in prossimità del porto norvegese di Narvik (forse la missione nella versione inglese è "inspite of everything". Uso questa missione perché non c'è nessun attacco aereo che mi possa falsare gli effetti.
I Tribal vengono affrontati da DD 34 GER e si sparano cannonate fra loro. Io con il sommergibile in emersione cerco di avvicinarmi alla max velocità alla corazzata:
con i valori 0.40 e 0.70 non ricevo alcun colpo avversario, riesco con il cannone di bordo ad affondare 3 DD Tribal e alla fine a ridurre a mal partito la Queen Elizabeth ad una distanza iniziale di circa 5 km e che alla fine termino con un solo siluro senza che la corazzata mi abbia mai sparato un colpo.
Forse siamo sulla strada giusta! Per adesso sembra che l'AI avversaria sia azzerata, proverò con intervallo 0.50-0.80 e poi 0.60-0.90 per vedere se c'è qualche differenza nella reazione avversaria GB e per avvicinarmi alla realtà perché è ovvio che debba ricevere qualche cannonata se in emersione sono così temerario da essere al di sotto di 10 km dal nemico.
Ti farò sapere.
Benvenuto anche da parte mia Iscandar!
Maurizio
3 hours ago, GatoClass said:
Ciao Luca,
# for non-merchants
    # for merchants
Ti farò sapere.
Maurizio
Wow questa è un ottima notizia Maurizio complimenti per i test.
Io nel frattempo
Cerca e cerca ho trovato questo post di TDW che conferma un pò delle nostre teorie
La parte più interessante è quella che ho evidenziato in grassetto,alla fine,ma magari tu riesci a trovare altri spunti:
TDW, is possible to make a time limit for the HK groups? I mean, 20 hours (or more) of cat &mouse play is way to much for a game. It's realistic, but I dont see anybody able to spend 20 hours of their lifetime into a game trying to dodge some AI that wont give up hunting you. I'm thinking about something like.. if no TC used, set hunt limit to 1 - 2 hours, then loose contact.
Risposta di TDW:
There are two possible ways you could do this. One is to cut the time they can search for you and/or the other way is increase fatigue over time. These values can be found in \data\Scripts\AI\init.aix
To cut time they can search for you play with these values (below are all in seconds):
# Hunter-Killer group spiral search time upon lost contact
HK_SPIRAL_MIN_SEARCH_TIME = 180.0; # used as min value of a Random function
HK_SPIRAL_MAX_SEARCH_TIME = 420.0; # used as max value of a Random function
# Hunter-Killer group wait time inbetween spiral searches
INVESTIGATE_FOLLOW_WAYPOINTS_TIME = 990.0; # 15 mins (90 to account for CONTACT_LOST_BEGIN_SEARCH_TIME)
# for escorts that are guarding convoy but attacking a contact, this is the time they can keep attacking when contact is lost
PLASTER_GUARD_CONVOY_DC_WAYPOINTS = 360.0;
# this is the time that if a unit is a director and the contact lost time >
# MAX_CONTACT_LOST_DC_TIME it waits until contact lost time is this value before
# heading back to convoy and following it's waypoints (not part of HK group)
DIRECTOR_SEARCH_TIME = 900.0; # 15 mins
CONVOY_ESCORT_SPIRAL_TIME = 600.0;
to play with fatigue adjust these values:
SHIPFATIGUEMIN = 0.5; # min time of current tier (ShipWatchRotation / 4) when next tier starts
SHIPFATIGUEMAX = 1.5; # max time of current tier (ShipWatchRotation / 4) when next tier starts
I personally would play with the fatigue numbers. I would increase all of them 0.025 at a time and test until I got what I was looking for. The fatigue numbers above reduce the sensor effectiveness of the ship's sensors by the amount shown on each tier change of fatigue. If you want them to enter fatigue faster then adjust SHIPWATCHROTATION to a small number
Ciao Luca!
Vecko ti ha risposto ma afferma che il problema c'è e dice: "Ti capisco. Ho parlato dello stesso problema molto tempo fa, ma non credo che ci sia una soluzione per questo ... SH AI è preciso e questo non è solo il caso di SH5. Probabilmente è hard codded." Quindi ci sarebbe poco da fare.
Ho provato in init.aix con l'intervallo 0.50 0.80 ma così il sommergibile viene colpito forse dopo qualche minuto rispetto ai valori di TWoS, ma comunque i danni sono già notevoli dopo i primi colpi ricevuti, per cui l'unica tattica preventiva sarebbe la solita immersione rapida per evitare i primi danni che comunque sono sempre micidiali.
Con l'intervallo 0.50 0.70 le cose si normalizzano un po' di più, c'è il tempo nella missione che uso io a far fuori almeno un paio di Tribal, poi un paio di DD 34 GE riescono a far fuori altri Tribal e probabilmente si attiva la routine che aumenta la stanchezza e quindi riesco anche ad affondare la corazzata.
Sempre con l'intervallo 0.50 0.70 nella missione del Gryf sono riuscito a far fuori il posamine che aveva avuto già il suo daffare nel respingere l'attacco aereo e quindi anche qui forse è intervenuta la solita routine che ha neutralizzato la capacità del Gryf di reagire. Infatti neanche dalla distanza di 4 km ha sparato un colpo in risposta ai miei che l'hanno colato a picco.
Non so se sia la soluzione ma per me al momento l'uso dell'intervallo 0.50-0.70 nel file init.aix è il migliore ma si tratta sempre di testarlo con altre missioni. Ci sono troppe variabili anche random che intervengono e non è facile trovare il giusto equilibrio. Forse intervenendo anche nel file guns_radars_01.sim nel range dei cannoni, nella velocità di elevazione ecc...
Comunque qualche risultato è uscito fuori. Prova anche tu a variare in init.aix i valori min e max così confrontiamo i pareri.
Ciao!
Maurizio
Aiuto mi si è bloccato il computer e non carica più windows 7. È come se non riconoscesse più i due HD interni. Forse è solo l'alimentatore che è partito ma non so a chi rivolgermi. Qui abito da poco tempo e devo cercare qualcuno che lo ripari. Per un po' non ci sentiremo.
Maurizio
Maurizio
Accidenti,ti auguro di risolvere al più presto...e con poca spesa!!
intanto sto facendo test..... confermo i tuoi risultati come inizio... ma voglio provare anche altro... appena ho novità scrivo
Luca
11 minutes ago, GatoClass said:
Ciao Luca dovessi farmi il computer nuovo ci sono problemi fra SH5 e windows10? Avevo windows 7
No no io sto giocando con W10 ed una scheda ati radeon 4650...non più supportata da Ati... eppure funziona .
Guarda che ho trovato in data\Cfg\sim.cfg
AI surface ships sensors cfg file
[Mech]
Waves amplitude=0.4                    ;[0,1]
Waves attenuation=0.65                    ;>=0
[AI Cannons]
;The degrees at which the AI could be off when aiming guns at you
Max error angle=4.5                ;[deg]  was 3, increased 33%
Max fire range=7000                    ;[m]    was 6000
Max fire wait=12                    ;
Sembra abbia qualche effetto..
Ma non vorrei dirlo troppo presto
9 hours ago, GatoClass said:
Molto interessante! Per il mio computer forse è la scheda madre da quello che ho letto in rete.
Mannaggia: avrò tutto da reinstallare!
Acci...guaio grosso questo.. Mi spiace Maurizio,vedi il lato positivo,avrai un PC più performante...comunque è sempre na rottura quando succede!
Ascolta, ho scoperto che il modder Gap qualche anno fa aveva tentato di metter le mani sull'accuratezza,ho provato a contattarlo, se ci son novità vi faccio sapere.
Luca
Maurizio
Ho avuto seri problemi anch'io recentemente, accendevo ma nulla..........il tutto in concomitanza con gli aggiornamenti di Windows
Io ho Win 10 a 64 e non ho alcun problema con SH5
13 ore fa, Von Faust ha detto:
Anche con Win 10 pro 64 SH5 gira a meraviglia
Modificato da marcello64
9 hours ago, marcello64 said:
Ciao.....dove trovo questa cartella o file che sia?
Ciao Marcello64 che MOD usi?
Devi avere installato TWoS (o almeno TDW patch)
Clicchi sull'icona di topolino che hai sul desktop, poi scegli la lingua con cui hai installato Sh5 poi su file(in alto a sx),poi su Open ( il primo in alto) ti si apre una finestra con un solo file, clicchi 2volte (apri) quello ed eccoti su OFEV... Cerchi SOAN (in alto clicchi la freccetta a destra per far scivolare le cartellle) apri, clicchi su true (predefinito ) e metti la spunta su false, apri ancora file in alto a sx) e ora su Save.
Più difficile dire che fare
Ciao Prima_Legio, ho installato il TWoS e ho seguito alla lettera la spiegazione che hai fornito. Ti posso chiedere un'altra cosa? Dopo circa un lustro ho reinstallato SH5 con appunto il TWoS, ma non riesco più a raccapezzarmi sul come si affondano le navi e soprattutto con il mod "Real Navigation" ove mi scompare addirittura il TDC e in pratica ho un sommergibile che non fa il suo lavoro. Mi puoi spiegare perchè succede questo?
Prova a guardare questo video che ho fatto per te e fai caso ai tasti che premo, magari si tratta semplicemente di questi
On ‎19‎/‎04‎/‎2019 at 12:12, GatoClass said:
Ciao Luca!
Concordo anch'io. Sono passato da poco a LSH con qualche aggiunta extra (tra queste le voci in italiano) e devo dire che non è affatto male.
Io invece per colpa tua e di prima_legio (😉😉) mi avete fatto venir voglia di inventarmi qualcosa e mi son ributtato su alcune modifiche grafiche che avevo nel cassetto 😀
      521,5k
