Von Faust
*** Red Ssbn *** - Giovedì 23 Aprile
*********************** START ENCRIPTION MESSAGE *************************
************** TITLE MISSION: Red SSBN *************
TO ----> DW BETASOM XI FLEET
RES: HIGH / MOD: RA - DWX 1.36 + Betamod 4.1.1 / REQ.MIN: BASE BETASOM VIRTUAL NAVY ACADEMY (for betasom players)
RATIO DIF: MID *** /TMA: AUTO - OPTIONAL MANUAL / LIMIT TIME: +2,30 HR from zulu
CONTACT: TS3 / TIME: 21.00 CET / DAY: 23 Aprile
La missione ha preso spunto dal seguente topic: http://www.betasom.it/forum/index.php?showtopic=16692&page=2&do=findComment&comment=470056
Third Borey-Class Strategic Nuclear Submarine Joins Russian Navy
Russia’s third Borey-class nuclear-powered ballistic missile submarine, the Vladimir Monomakh, was officially inducted in the Russian Navy on Friday, the Sevmash shipyard reported.
“The ceremony of raising the Russian Navy colors on the Vladimir Monomakh submarine on Friday, December 19, at Sevmash,” the shipyard’s press-service said in a statement.
According to the statement, the submarine will soon leave a naval base in Severodvinsk in northern Russia to join the 25th Submarine Division of the Pacific Fleet based in Russia’s Far East.
Borey-class submarines are to become the mainstay of the naval component of Russia’s strategic nuclear deterrent, replacing the aging Typhoon-class and Delta-class boats. Russia expects a total of eight Borey subs to enter service with the navy by 2020.
The first two Borey-class nuclear subs, the Yury Dolgoruky and the Alexander Nevsky, were commissioned in January and December 2013 respectively. The fourth and fifth subs of the class, the Knyaz Vladimir and the Knyaz Oleg, are currently under construction at the Sevmash shipyard.
Sevmash confirmed Friday that construction of the sixth Borey-class submarine, the Knyaz Suvorov, will start on December 26.
Il comando ci ha inviato l'ultima immagine satellitare della zona critica:
FOTO SATELLITARE INVIATA DAL COMANDO
Penetreremo da Nord e da Sud-Ovest, prestare la massima attenzione.
La Russia ha completato i test dei primi 3 Borey e pare siano in procinto di prendere il largo verso località strategiche visto che il clima internazionale è molto caldo.
Lo scopo del nostro team è quello di individuarli ed affondarli.
Si entrerà in un area fortemente presidiata da unità russe, prestare quindi la massima attenzione.
Sarà molto importante coordinarsi al meglio con le unità aeree in modo che queste abbiano il campo libero per la ricerca dei 3 SSBN in una zona piuttosto vasta.
TEAM Betasom
- Type U212 (ITA)
- MH-60
- Los Angeles FLT II
- Trechant
- Atlantic (ITA)
La composizione del Team può subire modifiche anche all'ultimo minuto.
Presenti:
- Von Faust
- Iscandar
- Regia Marina
- Blowyaz
- Subbuster ITA
Edited by Von Faust
Bellissimo scenario, peccato che non possa esserci... :sad:
Questa è tutta da vedere, ho tirato giù la missione in 15 minuti senza testarla :laugh:
Purtroppo il tempo a disposizione è pochissimo, si fa quel che si può per ora :sad::unsure:
EDIT: ho ordinato e sistemato tutte le ultime missioni che ho fatto, poi vi farò l'elenco per vedere se qualcuna si può inserire nella Wall of Mission
Edited by Von Faust
Regia Marina IN (come gia anticipato).
Una domanda Fausto, ma l'MH-60 sarà basato da qualche parte? ce la farà con il carburante per tutta la missione?
Grazie Fausto: ti adoro!
:wink::laugh:
Questo se non mi riporti qualche informazione sulle esercitazioni delle quali accennava Totiano
Edited by Von Faust
scusate purtroppo devo rinuciame ( ho la febbre alta )
spiace tantissimo.,,
Mi spiace, riprenditi presto !!!
io affondato dal solito kilo, avevo scovato un boery, ho lanciato, il kilo mi ha controlanciato con subroc, e mi ha beccato.
il boery ha usato una balena per coprirsi.
come è finita?
No words..... abbattuto da un sub arenato .... Una Volta che il Kamidrakken non c'è ci penso io a suicidarmi .... STOP .... :smiley21::smiley22:
Davvero peccato perchè fino ad allora è stata una missione fantastica, giocata da tutti i partecipanti in maniera esemplare ed in totale sinergia !!!
Mi sono divertito davvero tanto ! Grazie mille all'editor ed ai miei colleghi d'avventura !
Ho fatto il debriefing nell'apposita sezione :wink:
Ho spostato i post relativi.
