SeLaRgIuS Inviato 29 Novembre, 2011 Segnala Share Inviato 29 Novembre, 2011 Ciao a tutti, ho da poco re - installato SH5 ed ho un problema: il gioco parte normalmente, carica senza troppi problemi e non si blocca quasi mai ma, quando provo ad aprire la mappa di navigazione per tracciare la rotta, lo schermo si oscura e torna al Desktop con il Game Launcher. ho provato a disinstallare il gioco ma il problema persiste nonostante, per circa un mese, non sia successo niente di tutto questo. qualcuno può aiutarmi? ------------------ System Information ------------------ Time of this report: 11/29/2011, 19:50:45 Machine name: UTENTE1-02A3915 Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.101209-1647) Language: Italian (Regional Setting: Italian) System Manufacturer: System manufacturer System Model: P5K SE/EPU BIOS: BIOS Date: 03/14/08 11:20:57 Ver: 08.00.12 Processor: Intel® Core2 Quad CPU Q6600 @ 2.40GHz (4 CPUs) Memory: 3072MB RAM Page File: 910MB used, 4045MB available Windows Dir: C:\WINDOWS DirectX Version: DirectX 9.0c (4.09.0000.0904) DX Setup Parameters: Not found DxDiag Version: 5.03.2600.5512 32bit Unicode ------------ DxDiag Notes ------------ DirectX Files Tab: No problems found. Display Tab 1: No problems found. DirectDraw test results: All tests were successful. Sound Tab 1: No problems found. Sound Tab 2: No problems found. Music Tab: No problems found. Input Tab: No problems found. Network Tab: No problems found. -------------------- DirectX Debug Levels -------------------- Direct3D: 0/4 (n/a) DirectDraw: 0/4 (retail) DirectInput: 0/5 (n/a) DirectMusic: 0/5 (n/a) DirectPlay: 0/9 (retail) DirectSound: 0/5 (retail) DirectShow: 0/6 (retail) --------------- Display Devices --------------- Card name: ATI Radeon HD 4350 Manufacturer: ATI Technologies Inc. Chip type: ATI display adapter (0x954F) DAC type: Internal DAC(400MHz) Device Key: Enum\PCI\VEN_1002&DEV_954F&SUBSYS_E990174B&REV_00 Display Memory: 1024.0 MB Current Mode: 1024 x 768 (32 bit) (75Hz) Monitor: Monitor Plug and Play Monitor Max Res: 1600,1200 Driver Name: ati2dvag.dll Driver Version: 6.14.0010.6999 (English) Citare Link al commento Condividi su altri siti More sharing options...
Von Faust* Inviato 29 Novembre, 2011 Segnala Share Inviato 29 Novembre, 2011 In precedenza avevi installato qualche mod ? Dopo che hai disinstallato hai provato a vedere se c'era qualche "residuo" di installazione (cancella manualmente la cartella di SH5) ed hai eliminato la cartella dei salvataggi e configurazioni nella cartella Documenti\SH5\... ? Citare Link al commento Condividi su altri siti More sharing options...
SeLaRgIuS Inviato 26 Febbraio, 2012 Autore Segnala Share Inviato 26 Febbraio, 2012 Ho provato a caricare il salvataggio precedente all'ultimo e non mi da più problemi. Citare Link al commento Condividi su altri siti More sharing options...
SeLaRgIuS Inviato 3 Marzo, 2012 Autore Segnala Share Inviato 3 Marzo, 2012 In precedenza avevi installato qualche mod ?Dopo che hai disinstallato hai provato a vedere se c'era qualche "residuo" di installazione (cancella manualmente la cartella di SH5) ed hai eliminato la cartella dei salvataggi e configurazioni nella cartella Documenti\SH5\... ? Ciao, il problema si è ripresentato (proprio ora che ho affondato due portaerei porc... :s05: ), come posso risolverlo senza cancellare i salvataggi? non ho installato nessun mod, il gioco gira bene ma ogni tanto da qualche problema di grafica (equipaggio in coperta senza testa oppure, improvvisamente, tutti i comandi diventano dei quadrati bianchi pur continuando a funzionare come prima) HELP!!! Sergio Citare Link al commento Condividi su altri siti More sharing options...
Von Faust* Inviato 5 Marzo, 2012 Segnala Share Inviato 5 Marzo, 2012 Ciao,il problema si è ripresentato (proprio ora che ho affondato due portaerei porc... :s05: ), come posso risolverlo senza cancellare i salvataggi? non ho installato nessun mod, il gioco gira bene ma ogni tanto da qualche problema di grafica (equipaggio in coperta senza testa oppure, improvvisamente, tutti i comandi diventano dei quadrati bianchi pur continuando a funzionare come prima) HELP!!! Sergio Ciao, ho spulciato il lungo ed in largo il forum di Subsim per cercare problemi analoghi ma non ho trovato nulla. Vengono segnalati strani problemi di crash ma non riferiti alla mappa. I problemi di grafica che segnali non sono assolutamente normali, non ho mai letto di problemi simili. Hai già provato ad aggiornare/reinstallare i driver della scheda grafica ? Sempre su Subsim quando si verificano strani problemi come il tuo consigliano di fare delle verifiche sul sistema con questo programma: http://www.devicedoctor.com/ pare che qualche cosa che non va si trovi sempre. Citare Link al commento Condividi su altri siti More sharing options...
Von Taffond Inviato 5 Marzo, 2012 Segnala Share Inviato 5 Marzo, 2012 (modificato) Carissimi Comandanti, anche il sottoscritto ha lo stesso problema del crash appena si richiama la mappa di navigazione, e questo è capitato appena iniziata l'ultima fase della prima campagna (affondare due navi ammiraglie). Debbo dirvi che le ho provate proprio tutte ma niente. Se non arrivano buone nuove dalla sala radio, ordino all'equipaggio di abbandonare il vascello e successivamente l'autoaffondamento. Naturalmente non prima di aver scaricato tutte le salve di siluri a disposizione verso il maledettissimo bersaglio Ubisoft!!! :s05: Modificato 5 Marzo, 2012 da Von Taffond Citare Link al commento Condividi su altri siti More sharing options...
Von Faust* Inviato 6 Marzo, 2012 Segnala Share Inviato 6 Marzo, 2012 Sto provando a chiedere in giro a guru vari, capirne il motivo è veramente difficile. Gli aggiornamenti (patch) li avete installativero ? A presto Citare Link al commento Condividi su altri siti More sharing options...
Von Taffond Inviato 6 Marzo, 2012 Segnala Share Inviato 6 Marzo, 2012 Grazie Von Faust; si certo, gioco patchato regolarmente. La cosa strana è che sino alla fase della campagna citata tutto era (più o meno ) ok. Crash anche caricando un salvataggio precedente... Situazione veramente frustrante!!! :s05: Citare Link al commento Condividi su altri siti More sharing options...
