Drakken
*** Special Force Ra ***
*********************** START ENCRIPTION MESSAGE ***************************
********************* TITLE MISSION: SPECIAL FORCES *************************
TO ----> DW BETASOM XI FLEET STRATEGIC GRID IOPG
RES: HIGH / MOD: DWX 1.1 Beta / REQ.MIN: ADVANCED BETASOM VIRTUAL NAVY ACADEMY (for betasom players)
RATIO DIF: HIGH **** /TMA: AUTO - OPTIONAL MANUAL / LIMIT TIME: +2,30 HR from zulu
CONTACT: MSN / TIME: 21.00 CET / DAY: 11 Marzo
STRATEGIC GRID:
ENVIRONMENTAL CONDITIONS:
Sea State: 4 - Bottom type: Rock - Weather: Overcast - SSP Type: Surface Duct
HQ BLUE FORCE:
OBJECTIVE:
Primary objective is to release and to make to reach the Special Forces not less than 500 yards from the Naval Base Yellow SV OBT that is located to the North of the Devil's Island
ROE:
You can engage any hostile units, but not NEUTRALS units. The loss of "only one" neutral unit will envolve the loss of the game.
ORDER OF BATTLE:
SSN 21 "Seawolf"
SSN 773 "Cheyenne" ---> C.te Stefano74
SSK "Todaro" ---> C.te Sertore
FFG 57 "Reuben James" + 2 Seahawk Ready 30 - 60
HQ RED FORCE:
OBJECTIVE:
Primary objective is to release and to make to reach the Special Forces not less than 500 yardses from the Naval Base Orange BS OBT that is located to the South of the Devil's Island
ROE:
ORDER OF BATTLE:
SSN K335 "Gepard"
SSN K157 "Vepr" ---> C.te Von Faust
SSK "Lada" ---> C.te Kalinin
DDG "Tributs" + 2 KA-27 Helix Ready 30 - 60 ---> C.te Drakken
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> END MESSAGE
Comandanti facciamo una prova in multy con la MOD RA 1.1 per vedere se in multy regge la potenza della flotta di BETASOM....
Edited by Drakken
Sertore IN.
SSK Lada
PS: non ho ancora installato RA 1.1 sul PC di casa: questa sera provvedo ed in caso di problemi faccio seguito domani. :s68:
Edited by sertore
Guest AleX24
assente per un 18esimo (già il secondo in una settimana :s12: ) peccato a questa di RA volevo partecipare.. :s05:
buon divertimento :s55:
Gepard of course!
Che alla fine è il mio sub, quindi quale modo per testarlo al meglio? :s10:
Consiglio a tutti di dare un occhiatina al manuale delle armi di RA, prima di iniziare la partita, anche per sapere cosa caricare e non a seconda degli obiettivi da fare... :s41:
VON FAUST IN
SSN K157 "Vepr"
EDIT: Se abbiamo intenzione di metterlo alla frusta anche in multystation mi piazzerei con me stesso ( :s68: ) ed il portatile fisso sui sonar.
Prepariamo un piano di emergenza con AT3 in caso di seri problemi di crash ?
Edited by Von Faust
Andrei volentieri in multistation visto che non è rimasta nessuna unita che posso pilotare, percui chi è cosi gentile da prendermi a bordo? :s04:
Passo sul Todaro e lascio il Lada a Kalinin. :s02:
PS: evitiamo multistation nel primo test di RA... come dire, non cerchiamocele! :s68:
Edited by sertore
Da parte NATO ovviamente, ma fino a domani pomerigguio non ho la conferma di esserci.
Piattforma quella che vuole l'editor.
io questa settimana non posso esserci per motivi di lavoro.
divertitevi e pensatemi :s10:
elio
Se altri giocatori in possesso di abilitazioni per unità già occupate fossero disponibili posso spostarmi dove è necessario a discrezione dell'editor. :s68:
Edited by sertore
Per quanto mi riguarda dove vuoi tu va benissimo (calcola però i miei crash sicuri al 90 % con la fregate su pc fisso, potrei provare però col portatile cosa mai fatta).
Grazie
Mi piacerebbe non poco essere dei vostri, purtroppo anche questo giovedì sono impegnato a cena :s06:
Testate per bene questa RA che al prossimo giro mi piacerebbe controllare il nuovo 212! :s44:
Scusate se e' off topic ma e' importante sopratutto alla luce del fatto che testerete Ra questa sera.
Annuncio Importante :
La mod RA e' stata testata unicamente sotto XP SP3.
Se installate la mod correttamente su Vista o 7, non importa se usate modalita' di compatibilita' con XP potrebbe non funzionare e dar luogo a problemi strani.
Quindi se testate la mod, fatelo sotto XP SP3.
Con Von Faust abbiamo cercato di capire perche' la sua installazione dava problemi strani. Come ricevere il TIW da 10 nm. Abbiano testato una missione da me progetta, io ho verificato che il lancio di siluri da 7 nm non danno luogo a TIW, mentre si ricevono senza alcun problema i missile launch warnings dei lanci dei subrocs. Lui l'ha testata e non ha funzionato. Alla fine dopo aver verificato che la sua mod era non corrotta, e scompattata correttamente l'unica cosa che abbiamo trovato di diverso tra la mia installazione e la sua e che io ho XP SP3 mentre lui ha Windows 7.
Ripeto il readme dice :
Requirements:
Game version - 1.04 build 378.
Language - ONLY ENGLISH VERSION ( Or Any National Language Localization Patched ENGLISH v 1.04 ).
Free Space: It is desirable 1 Gb on Your hard Disk.
This add-on be tested and installing at OS MS Windows-XP Sp3. Later version OS Not Checked.
Quindi siete pregati di usare XP SP3 per testare la mod.
Edited by goldorak
Lascio libero il mio posto sul Gepard, mi ero dimenticato che stasera facciamo lezione con Gladiatore sul P-3c... :s68: :s68: :s68:
Mi era proprio passato... :s12: :s14:
In caso di emergenza ho preparato una missione con AT3 con gli stessi partecipanti.
Tenete in caldo anche AT3 :s01:
Ehi Gold, la prossima volta scrivilo più grosso....
:s03: :s03: :s68:
comunque grazie per la segnalazione. :s02:
Confermo la mia partecipazione
Menomale che c'è Stefano a tener alta la bandiera yankess... e gli altri ??? :s03: :s68:
Non solo la bandiera............... :s01: :s03: :s10:
Marco puoi cambiare il sub con il mio cheyenne?
Edited by stefano74
