Navi Da Guerra Presenti In Shv
Drakken
Direttamente dal sito ufficiale di Silent Hunter V una rassegna delle maggiori unità di superficie presenti nel gioco:
Dati in aggiornamento settimanale:
CORAZZATA CLASSE "LITTORIO"
Dati:
Type: Battleship
Nation: Italy
Appearance: 01/04/1940
Main Guns: 3 × 3 381 mm (15.0")/50
Sec Guns: 4 × 3 152 mm (6.0 in)/55
Max Speed: 31.50kts
Length: 224.5 to 237.8 m
Height: -
Draught: 10.44 m
Width (beam): 32.43 to 32.9 m
Tonnage: 41177
Armor:
Vertical: 280 millimetres (11"")
Horizontal: 36 millimetres (1.4"")
Turrets: 350 millimetres (14"")
CORAZZATA CLASSE "BISMARCK"
Dati:
Type: Battleship
Nation: Germany
Appearance: 01/08/1940
Main Guns: 8 × 38 cm (15 in) SK C/34 (4 × 2)
Sec Guns: 12 × 15 cm (5.9 in) (6 × 2)
Max Speed: 30 kts
Length: 241.6m
Height: -
Draught: 9.3 m
Width (beam): 36 m
Tonnage: 41 700
CORAZZATA CLASSE "NELSON"
Dati:
Type: Battleship
Nation: British
Appearance: 1927
Main Guns: 9 × BL 16 inch Mk.I guns (3×3)
Sec Guns: 12 × BL 6 inch Mk XXII guns (6×2)
Torpedoes: 2 × 24.5-inch (622 mm) torpedo tubes Mk.I
Max Speed: 23kts
Length: 216 m
Height: -
Draught: 9 m
Width (beam): 32 m
Tonnage: 33950
Armor: Belt: 14", 9–13" closing bulkheads
Middle deck: 6.25" over magazines, 3" over machinery spaces
Lower deck:6.25 " over steering gear
Bulkheads : 1.5" longitudinals
Conning tower : 13.5" sides, 7.5" roof, 6" communication tube
Director control tower : 6" sides, 4" roof
CORAZZATA CLASSE "NORTH CAROLINA"
Dati:
Type: Battleship
Nation: American
Appearance: 01/04/1941
Main Guns: 9 × 16 in (406 mm)/45 caliber Mark 6 guns
Sec Guns: 20 × 5 in (127 mm)/38 caliber Mark 12 guns
Max Speed: 28kts
Length: 222.113 m
Height: -
Draught: 10.820 m
Width (beam): 33.017 m
Tonnage: 37200
Armor: Belt:12" on 0.75" STS (305 mm on 19 mm), inclined 15 degrees, tapering to 6.6" on 0.75" STS (168 mm on 19 mm) at lower edge[10] Barbettes: centerline forward: 14.7" (373 mm);sides 16" (406 mm);centerline aft 11.5" (292 mm) Turrets: face plates 16" (406 mm); sides 9.8" (249 mm); back plates 11.8" (300 mm); roof plates 7" (178 mm) Secondary guns: mounts 1.95" (50 mm); magazines 1.95" (50 mm) Decks: Centerline total 7.07" (180 mm); Outboard total 7.7" (196 mm) Conning tower: centerline sides 14.7" (373 mm); beam sides 16" (406 mm); roof sides 7" (178 mm); bottom plates 3.9" (99 mm); communication tube 14" (356 mm)
INCROCIATORE PESANTE CLASSE "HMS HOOD"
Dati:
Type: Battlecruiser
Nation: British
Appearance: 1918
Main Guns: 8 x 15"
Sec Guns: 12 x 5.5"
Torpedoes: 4 x 21"
Max Speed: 29 kts
Length: 262m
Height: 47m
Draught: 10m
Width (beam): 31.7m
Tonnage: 49140
Armor: 12''
PORTAEREI CLASSE "ILLUSTRIOUS"
Dati:
Type: Aircraft Carrier
Nation: British
Appearance: 01/05/1940
Main Guns: 16 × QF 4.5 in Mk.III (114 mm L/45) in 8 × twin mounts BD Mk.II
Sec Guns: 48 × QF 2 pdr Mk.VIII (40 mm L/40) in 6 × octuple mounts Mk.VIII
Max Speed: 30.5kts
Length: 205 m
Height: -
Draught: 8.5 m
Width (beam): 29 m
Tonnage: 23207
Modificato da Drakken
Questa discussione è chiusa.
